DIY 18' manifold swap into 15-17'
S550MG
Alabama
2016 S550
Spliced the pigtails in. I’m going to go back this weekend and make sure they’re in the right order
More than likely you got a wire crossed up or a weak solder joint.
SNOOPY
BEACH
2015 S550
If locking out the flaps and turning off in the tune, is any rewiring still required?
BULL1TT
culpeper, va
2015 mustang GT, 2001 Bullitt
No. You will just have 4 plugs that are left unconnected.
S550MG
Alabama
2016 S550
Do you have Dyno results for the OP install?
Not yet. I did a before dyno with only CAI and exhaust and put down right at 390 wheel. Now I’ve added the 18’ manifold and Lund flex tune so we’ll see what the gains are. I’m not sure when I’ll get back to the dyno but it’ll be in the next few weeks. I’m hoping for 440-450 whp.
JonAMR
Cleveland
2017 mustand gt
What changes when you are using lockouts. Do any of the vacuum lines change. I know you cap off the back vacuum line. Just what goes on up front differently?
EODTech87
Copperas Cove, Texas
2015 Mustang GT Premium
The vacuum port in the back is just a pass through to the vacuum port in the front. You can leave both those ports alone and block off the port coming from that distribution block instead.
DHs550
Oklahoma
2015 Mustang GT
Is there any way you could do a schematic for this? I just switched to the lockouts and wasn’t aware the vacuum lines changed
EODTech87
The vacuum 1 ports on the front and back of the intake manifold can be left disconnected and uncapped as they are interconnected with one another and nothing else.
You can remove this piece and cap it or leave it on and cap it. This is what supplies the vacuum to the IMRC which are being deleted.
Velgen
2017 Mustang GT
Can someone help? Does this look right for a Vortech/paxton car with no IMRC? Do i need to add the 4 port check valve? Got my boost reference by T ing the brake booster to manifold port. Thanks in advance
JonAMR
Cleveland
2017 mustand gt
So if you lockout the imrc do you still connect this to vacuum 1 or would you cap it off
