aligment recommendations for new suspension?
Caballito
Sacramento, ca
2017 Mustang GT Base
hi guys so i went with the good.ppl of steeda for my suspension needs, heres what i installed maybe you guys can recommend me an aligment setup that more street than track but that will benefit my new suspension but tgat wont kill my tires in the inside. thanx in advance.
dual rate springs
adjustable shocks
sway bars
irs aligment dowels
irs aluminum spacer bushings
stop the hop braces
like i said, street first track second, i do go to 3 to 4 events a year. thanx guys
ForTehNguyen
Houston, Texas
15 GT
may need camber bolts/plates and rear toe mods to be able to correct the camber/toe changes
Norm Peterson
corner barstool sitter
Norm
'08 GT #85, '19 WRX
If you're trying to find a "middle ground" between street and track, the harder your normal street cornering gets, the more negative you'll likely want front camber to be. Either absolutely or at least relative to factory preferred as compared to rear camber and its factory preferred spec. Be honest with yourself, most people rarely (if ever) intentionally hit 0.5g in the corners.
Having a minimal amount of toe-in up front won't be the end of the world in terms of tire wear, but it will make the steering less nervous in street driving than any static toe out. Maybe 0.10° or 0.15° total.
Norm
Caballito
Sacramento, ca
hey norm i was thinking of basically doing as much as camver as possible since i dont have a camber kit and maybe doing the toe in the specs u recommneded, what u think.
