Enoch
Poly.... the red ones. They were in a week and I couldn’t wait to get them out.Did you use the aluminum or poly inserts?
Worst : Boot lid pull strap - Manders said the plastic clip would never hold , and of course he was right.
Was it one of @Centurion07 's if so he'll send you another plug, if it was one of stangNz's one, it was never gonna work. Tony's on mine so far has been fine, and he'll be first to admit I'm a bit heavy handed with it lol.
I think it was stangNZ , it came with two clips and after the first one broke the strap is just an ornament.
I didn't realise there was a better fix out there , I'll look into that.
Cheers
:cheers:Yeah, too much force exerted on it.
@Centurion07 will sort you out with a strap (think they're around 10-15 quid or something). Come in different colours but the "Holder" actually holds, his instructions say "cut" a slither off the plastic, but I've found them easy enough to line up with the hole and rubber mallet tap them in, then fit the screw and plastic washer. Use mine pretty much every day and it's been fine. I had my previous clip break however that was because I'd cut it too thin, without cutting it, few months on (Got it just before modurstang in june/july last year) it's been fine since !
Curious to know what issues you had with the TriAx shifter - we fitted our first one last week and the customer loves it. Admittedly it took us a while to work out the best way to fit it so that the reverse collar doesn't hook up but once we'd sorted that out it seems to do the job (of being shorter than stock) quite well.Best- painted stripes, springs, cdc outlaws,tri bars. Hard to choose one really. Could be trumped by the ram air hood going on as we speak though. Worst- hood vents and the steeda tri ax short shifter. What a piece of shit that is!
