BMR Suspension New Product - Poly Cradle Bushings for S550 - BK047
BMR Suspension
Seffner, FL
2015 300A PP GT
Polyurethane Cradle Bushings for S550 Mustangs
BK047
Minimize wheelhop, improve handling, and enhance the rear stability of your 2015 Mustang with Polyurethane Cradle Bushings from BMR Suspension. Stock rubber bushings with voids are great for minimizing NVH, but deflect tremendously. This causes wheelhop, which reduces traction and can damage rear suspension parts. Designed from 95-durometer polyurethane, BMR’s cradle bushings center the cradle and greatly reduce deflection caused by the stock rubber bushings. BMR Poly Cradle Bushings (BK047) solidly connect the cradle to the chassis, reducing deflection and transferring more power to the tires. BMR designed the BK047 for street performance, drag race, and handling applications, making them the perfect wheelhop solution for any performance-based S550 Mustang. Each bushing is made to strict tolerances, which ensures high quality and an exact fit. These bushings reduce cradle movement and wheelhop, while increasing handling stability. This gives you a much-improved overall feel with moderate increases in NVH. Installation time is about 3-4 hours. Proudly made in the U.S.A.!
To preview all of BMR’s high-performance suspension parts, please visit www.bmrsuspension.com, email [email protected], or contact them at BMR Suspension, 928 Sligh Ave, Seffner, FL 33584, 813-986-9302, Fax: 813-986-8055.
rcb020
Dallas, TX
2015 Mustang GT
Would the BK047 and BK049 combo be good for a daily driver that sees the road course about once a month, or would you recommend CB005 instead? I assume the poly bushings are in between the Delrin and lockout kit in terms of NVH.
BMR Tech
Tampa, FL
Dion
Personally, for road course and street duty I recommend the CB005 instead of this kit.
The CB005 is going to provide less NVH, and work "almost" as good.
This kit, IMO is best suited for street / strip applications. I mean, don't get me wrong....it will work great on a road course, but so will the CB005 which is easier to install, and will provide less NVH.
