2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt) - Mustang6G.com 22 - Velgen Wheels - 1
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Bronco Forum Ranger Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, EcoBoost, GT350, GT500, Bullitt) - Mustang6G.com > Technical Subforums > Transmission & Drivetrain
Notices
Transmission & Drivetrain Everything related to transmission, drivetrain, gears, etc.
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 02-06-2017, 11:06 PM   #1171
Tony Alonso
M6G Moderator
Drives: '15 GT, '01 Bullitt, '09 Bullitt
Thanked: 1,073 Times in 649 Posts
Garage
iTrader Score: 0 reviews
Quote:
Originally Posted by mustang_guy View Post
Its mostly related to the PP diff in the cars. My 17 doesnt have it. I also didnt buy a PP. Ive still yet to read any non pp owners complain.
It's been a characteristic of my '15 GT without a performance pack since the first week I got the car back in November, 2014. I am used to driveline slop from the live axle days, so I haven't done anything about it.
__________________
2015 Ford Mustang GT Fastback
Magnetic Metallic (code J7) w/6-speed manual
Delivered 11/4/2014 w/5.0 miles - my journal thread
Tony Alonso is offline   Reply With Quote
Users thanking this:
Old 02-06-2017, 11:33 PM   #1172
mustang_guy
Drives: it has an engine!
Thanked: 1,316 Times in 1,010 Posts
Quote:
Interesting! I generally hear of no one having that complaint than the vast majority of PP owners. From what ive seen on inspection on a lift (ex ford master tech here) my buddies PP it was the torsen. Id wager if your trak lok is doing it possibly just needs an adjustment. Have you ever tried taking it in? What gear ratio do you have?
mustang_guy is offline   Reply With Quote
Old 02-06-2017, 11:41 PM   #1173
mustang_guy
I didnt see many older mustangs thud like some discribe during normal driving unless you no lift shifted or banged it hard enough. Is that what you're reffering to?
Old 02-07-2017, 12:33 AM   #1174
Tony Alonso
M6G Moderator
Garage
It's the 3.55 gear. I've not taken it in because many of the early posts in this massive thread have centered on cushy bushings in the IRS and the IRS cradle shifting. I really didn't want to get into any diagnosis or purchase aftermarket parts to modify my daily transportation. It only occasionally shows up, or at least I don't notice it as much.
__________________
Old 02-07-2017, 12:35 AM   #1175
Tony Alonso
M6G Moderator
Garage
I heard noise when shifting hard. I don't do that much these days. :-)
__________________
Old 02-07-2017, 01:14 AM   #1176
Kong76
Drives: 2016 Ingot Silver GT
Thanked: 138 Times in 111 Posts
Its mostly related to the PP diff in the cars. My 17 doesnt have it. I also didnt buy a PP. Ive still yet to read any non pp owners complain. Ive also told you that this isnt an uncommom thing on IRS equipped vehicles. I also dont see any autos complaining about it either. You just want to complain, in my opinion.
Well I have a base 2016 GT and mine has been doing this from day 1 as well. Noticed you straightened up your attitude when Tony responded. Why do you have to be such a prick? I've seen other threads where you respond the same.
Whats your problem? Napolean complex? No girlfriend? Not big enough? Gotta be something... tell us...
Kong76 is offline   Reply With Quote
Old 02-07-2017, 01:23 AM   #1177
Draklia
Drives: 2016 GT
Thanked: 64 Times in 44 Posts
I've had the thud since day one on my base '16 too. I am not convinced it's a problem in the fact that it will cause damage.
I thought it was just the backlash in the ring and pinion along with a pretty hefty drive shaft, that and the transmission doesn't really have anything in it to quiet it. But just guessing on that. It is annoying though, but life goes on (hopefully).
Draklia is offline   Reply With Quote
Old 02-07-2017, 01:34 AM   #1178
Asharus
Drives: 2015 Mustang GTPP
Thanked: 631 Times in 447 Posts
I've had it since day one. 27k miles and over 2 years later, not concerned at all. I've had several other manual trans cars (all Getrag trannies).
__________________
Previous:
2015 Mustang GTPP | Oxford White | 35% Llumar ATC Tint
Borla ATAK Catback with Black Chrome Tips
Current:
2018 Challenger R/T 392 Scat Pack A8 | White Knuckle | Bone Stock
Asharus is offline   Reply With Quote
Old 02-07-2017, 09:59 AM   #1179
EXP Jawa
EXP Jawa's Avatar
Drives: 1999 GT Convertible, 35th Anniversary package
Thanked: 200 Times in 145 Posts
People talk about it being a driveshaft issue, a rear end issue, a transmission issue. And you see some situations of replacing a part and it going away for one guy, but not another. Here's my best guess / theory.
The root cause may be there's some amount of drag across the clutch, even when disengaged. This causes the input shaft of the transmission to spin slightly when in neutral, but being in gear obviously provides enough resistance to stop it. When you're in neutral and move into gear, the inertia of the input shaft transfers to the transmission output. Depending on how much backlash is in all of the downstream components, you'll get a thud of varying degree as that inertia is transferred down the drivetrain and all of that lash is used up, forcing the input shaft to stall. More combined lash means more thudding.
So, if you have low lash in the axle, but a bit in the 2-piece prop shaft, putting in a 1-piece shaft reduces the lash - and the inertial movement - enough to make the thud less noticeable. But if there's also excessive lash in the axle, then you don't make enough reduction in system lash to change how the thud feels. It might be more noticeable off the bat in PP cars because 1) the 3.73:1 gears multiply the axle back lash more than the taller gearsets do, and 2) the Torsen lacks a preload spring, which masks the differential gearing lash in the clutch plate diffs. So, more perceived lash comes from the axle. But you can get it in other axle combinations if the prop shaft or transmission system lash is also high enough. You don't get it in A/T cars because the transmission obviously sidesteps the issue.
I could be completely off base on this, I'm just an axle guy. But this is the only thing I've been able to come up with that addresses all the facts as I understand them. You can chase various aspects of drivetrain back lash and improve the situation, but I'd bet that if the clutch could be set up so the clutch disc more fully disengages the pressure plate, the problem would disappear. At least that's my thinking...
__________________
Rick
'99 GT 35th Anniversary Convertible
'99 SVT Cobra Convertible
EXP Jawa is offline   Reply With Quote
Old 02-07-2017, 10:11 AM   #1180
wildcatgoal
@sirboom_photography
wildcatgoal's Avatar
Drives: '16 GT PP DIB
Thanked: 2,188 Times in 1,571 Posts
The point is, it's a 2015 MY car... there is no excuse for this. Not one single manual transmission vehicle I've driven or owned prior (Subaru, VW, BMW, Nissan Versa, Toyota Scion, '94 Honda Accord) have done the same. It's pitiful. But... you get used to it.
__________________
2016 GT PP | Instagram | My Build
Suspension: Steeda | Aero: Verus Engineering, Kognition Design | Engine/Power: Steeda, Solo Performance, ATI
Driveline: Steeda, MGW, Shaftmasters | Wheels/Tires: RAYS, Continental, Nitto | Cooling: Mishimoto
Brakes: GLOC, Ravenol, JLT | Fluids: Liqui Moly, BG, Pennzoil | Affiliation: JZilla Track Days
wildcatgoal is offline   Reply With Quote
Old 02-07-2017, 10:12 AM   #1181
Tony Alonso
M6G Moderator
Garage
Quote:
What do you think about the change in the '18 GT to twin-disc clutch and new dual mass flywheel? Purely for higher torque output?
__________________
Old 02-07-2017, 10:16 AM   #1182
EXP Jawa
EXP Jawa's Avatar
I'd expect that the main reason for doing that is increased torque capacity. I doubt it would be done as a thud improvement. In fact, I'd think that with dual-discs, there is an added level of complexity to getting it set up right. One disc might still drag and the other not.
__________________
Rick
Old 02-17-2017, 07:30 PM   #1183
mustang_guy
My attitude has zero influence based on his presence. Ill say what i want to say regardless. Im a bit too old to fear being banned on a forum. Maybe you should stop adding tone to text. Couldnt care less what your opinion of me is.
Quote:
Wrx and sti most definitely thud if shifted hard. Their issue is with their diff bushings.
Old 02-17-2017, 07:38 PM   #1184
skytop1
skytop1's Avatar
Drives: Mustang GT
Thanked: 122 Times in 85 Posts
I've decided to purchase a new 2018 Vette instead of the new 18' Mustang. I am tired of fighting with Ford.
__________________
GT PP with 428 SJC R Code
skytop1 is offline   Reply With Quote
Old 02-17-2017, 08:29 PM   #1185
5LITER
5LITER's Avatar
Drives: 2016 Gt base 6spd mans transmission
Thanked: 61 Times in 43 Posts
My previous car of 10 years was a mazdaspeed6. It also has a getrag transmission and makes the same thuds as my 16 gt. 120k miles later and it was fine until i sold it. I truly believe its a getrag thing.
5LITER is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
