wildcatgoal
@sirboom_photography
Like I've said elsewhere on this forum, the diff bushings do not reduce this noise. If anything, they'll increase it (if your car is prone to the noise). It is play within and between the transmission and differential, not the differential moving. I had a super similar (probably same) issue with a Chevy truck. Ultimately replacing the differential solved it. I was no longer able to literally, by hand, twist the drive shaft left and right a pretty significant distance and hear the exact clunk I heard in the truck. Guess what my drive shaft does? And it isn't the driveshaft itself that has play when twisted. It's what it is connected to.U tried the diff bushing and does not work right?
