Steeda's S550 Tri-Ax Race Short Throw Shifter is Here!
BluByeU
M6G SoCal Cruisers
SoCal (Temecula)
Rob HT
2015 Premium GTPP Recaros & Shaker 401a
Haha yes! Made my day. This shifter has already been ordered by a bunch, if you're looking to change up your shifting and never miss 2-3 again, let me know bud! :)
How ironic you would say "never miss 2-3 again". That in fact happened earlier today against a Challenger, still walked him, but def need to replace the stock shifter David.
Blitz
San Diego
Tony
2015 Mustang GT/PP w/Perfomance
cant wait to do a side by side comparison of this and the barton!
Blitz
San Diego
Tony
And guess who points my man rob at steeda??????:cool:
Cascadia_302
PNW
2015 RubyRed GT M6 Premium
OK [MENTION=10893]David@Steeda[/MENTION], had my Steeda Christmas list all set until you dropped this bomb!!!
So how to re-write this list? Chassis parts or Tri-Ax shifter:frusty:
Hold on,:doh: Tri-Ax shifter AND Chassis parts.:D
The Menace
No it's not that Fast...
California
Danny
Mustang GT
Damn I was going to see if you wanted my trans mount and driveshaft loop I'll be recycling when my Steeda Shifter gets here...
The Menace
California
Danny
Mustang GT
David@Steeda
David@Steeda
United States
www.steeda.com
David
Bolt-on, slammed S197
Ironic for sure! At least it didn't affect the outcome this time :)
:D Let me know if you need help re-writing it, English was my strong suit! You know I will make your list very attainable :cheers:
Where there's a will there's a way :)
Epiphany
Global
I like to disassemble things.
Steeda's S550 Mustang MT-82 Tri-Ax Race Short Throw Shifter is manufactured from high-quality aircraft-grade aluminum making it 20% lighter than the competitions' shifter assemblies. The shift lever itself on our Tri-Ax is made from heat-treated and nickel-plated 4140 steel, making it the strongest part out on the market. All hardware is stainless steel for the highest corrosion-resistance possible.
David, both Barton and MGW use 6061-T6. I assume you are using the same. What makes the alloy you are using any lighter than theirs?
Is this shifter reusing the stock multi piece linkage?
I wondered the same thing almost immediately because it isn't shown or mentioned. David, what material is the horizontal shaft that isn't shown that resides below the pivot? Does it exit a hole in the lower "box" and enter the circular stub you use with the rear bushing via a hole?
David@Steeda
David@Steeda
United States
www.steeda.com
David
This shifter does reuse the stock linkage.
They also use some steel in their designs. Since we design, engineer and manufacture everything in-house, we are able to put the strength where it needs to be and therefore save weight in other areas.
We are using 6061-T6 as well.
Epiphany
Global
Just to be clear David, when you say "this shifter does reuse the stock linkage" does that include the shaft and pivot cup inside the lower shifter box as well as the linkage that connects to the transmission "rod"?
I suppose a photo of the internals as well as an installed photo would help.
Guardstang
Hamilton, Ont
Shawn
2015 Ecoboost
The best mod I ever made on my 2001 Bullitt was a Steeda Tri-Ax, I wouldn't hesitate to install one in my 15 if it was a manual.
mustang_guy
United States
it has an engine!
Does this work with the magnum xl swap for us? I believe it did for the s197. Didnt want to assume it automatically would for the s550
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
I am pretty sure it does as that is the trans in their Steeda car. I am pretty sure it was tested on that car. That is my assumption :D
