- Banned
- #61
We will see, I know I get a ton of people telling me it sound amazing now.That may actually sounds pretty good with the ProCharger
Out of curiosity - what clutch are you planning on going with?
Apparently you can use a .75" space on the T/O bearing and run the GT flywheel which is a good bit lighter. At that point any aftermarket GT clutch would bolt right in. In fact, SPEC offers a steel and an alum flywheel for the 3.7 - and it has the bolt pattern for both 3.7 pressure plate and 5.0 pressure plate / clutch. But either one if @ $500.
Ram makes a complete setup for the 3.7 that eliminates the Dual Mass flywheel. The flywheel to work with their kit is actually the same flywheel they sell for the GT. Their kit requires their throwout bearing - which has the previously mentioned spacer built in.
The OEM GT flywheel is reportedly a tick under 22lbs and the OEM 3.7 DM flywheel is 32lbs.
https://ramclutches.com/mustang-clutches
Looks like the sensible way to go is use the GT flywheel $125 shipped, $15 for FPP 5.0 flywheel bolts and the SPEC Stage 1 clutch /PP (rated 550 ft/lbs) for @ $300. The .75" spacer is available through RAM PT#78513 for @ $90.
I don't know, I believe you have to but I wasn't sure why since the pulley bolts right on.Is it optional on the 3.7 kit? I remember helping install a Procharger on a LSx car and if I remember correctly that procedure was to pin the harmonic balancer to the crank (not just bolted - basically safety) and it was optional below certain HP / boost levels.
Thanks dude I will continue to update this thread from this name, since a Moderator had a power complex on me when I asked a simple question and banned my other account I was forced to make a new name to continue my build for everyone.This is so badass but the price of all this is seriously eye-watering lol. More power to you brother, I admire you for stepping out and making the FI leap.
I have been extremely busy going out of town competing so there will be some lapse.Any updates on the build? And van someone get this stickied for our group?
