sigintel
- Nov 24, 2015
- Republic of Texas, God's Country
- Ray
- 2018 GT
Well that was no help... GT uses a completely different design so no parallels exist. The image below though is the flexplate and flywheel for the 2018. Neither match what is seen in the 5.2 diagram.
Vibration Dampers
Could be because the 500 will have a Cross Plane Crank, it will be different from the FPC and the Auto. Different Vibration Mass and Locations.
CAD for the S550 has 350 Parts and 5.0/V6/4CYL mixed in the same drawings, so you can’t be really sure of everything.
Bracket on back of Engine/Passenger Side is for what?
No Direct Injection Connectors on the Harness. But, the 350 could get a bump in Power with it and as the earlier photos show, the 350 Intake Manifold May have room for the the DI Rails, Connectors and Wire Harness. At the least, only minor mods.
https://www.mustang6g.com/forums/showpost.php?p=2099529&postcount=49
Still using the 350 Fuel Rail and Pressure Sensor.
Where have I seen that belt routing before...So I saw this awhile ago when I first looked at 2018 wiring diagram info but just assumed that it was a different intake manifold for the 5.2 GT350 as these appear when looking at 5.2 diagrams for the 2018. Now that I look at it closer though I can see the supercharger underneath!
As stated, these images appear in the official 2018 wiring diagrams available from Ford.
*Also as a note... Do not look to much into the wiring information seen in the image as it appears that the wiring file is from a GT350 as you can see it go through the supercharger intercooler in a few places and the throttle position sensor connector is just floating in space.
No dry sump shown.... or is it....
Fun stuff:ford:
Lol... Heard a British chap rumor that someone was building a "wheels forward" composite semi-monocoque for Ford. Not sure what the wheels forwad part was about. That would be badass if TVR cut an engine supply or resource sharing agreement with Ford... S650 800hp dry sump track weapon.
