Coilovers Available for the S550 (LIST) - Seeking inputs and opinions
socalsnake
Earth
'15 5.0 GT PP
Like many of you, I’m ready to purchase a set of coilovers.
Its proving to be a hard decision as there is now a decent selection to choose from
Below is a list of what is currently available on the market along with their MSRP and links to their description.
I’d like to know what your opinions are and if you’re considering any of these coilovers and the reasons why.
FWIW, my car is a daily driver an will not see any track time. Also, I’ve had previous experience with KW V1, V3 and clubsports on BMW M cars and VW R32s and they performed very well, but I’m open to any quality product.
Also, in a couple of weeks, I’ll have a chance to ride in aFe’s own S550 equipped with their FeatherLight coilovers.
On to the list…
aFe Featherlight Single Adjustable Coilovers - Rebound Adjustable Only (MSRP is 2943.00 or 3364.00 if packaged with their sway bars), September Availability:
http://afepower.com/shop/details_ne...Mustang GT&year=2015&engine=5.0L&&brandID=142
BC Racing BR Type Single Adjustable Coilovers - Rebound Adjustable Only (MSRP is 1200.00), Available Now:
http://www.bcracing-na.com/br-type/
http://www.hypermotive.com/bc-racing-br-coilover-set-15-mustang/
Cortex Racing Xtreme-Grip Koni Single Adjustable Coilovers - Rebound Adjustable Only (MSRP is 2995.00), Available Now:
http://cortexracing.com/product/cor...tem-koni-single-adjustable-2015-mustang-s550/
Cortex Racing Xtreme-Grip JRi Single Adjustable Coilovers - Rebound Adjustable Only (MSRP is 3795.00), Available Now:
http://cortexracing.com/product/xtr...rtex-jri-single-adjustable-2015-mustang-s550/
Cortex Racing Xtreme-Grip JRi Double Adjustable Coilovers - Rebound and Compression Adjustable (MSRP is 4895.00), Available Now:
http://cortexracing.com/product/cor...r-system-double-adjustable-2015-mustang-s550/
Eibach Pro R1 Coilovers - soon to be released see Post #277, Page 16, for pics
Eibach Pro-Street Coilovers - soon to be released see Post #277, Page 16, for pics
ISC Suspension Coilovers - Rebound and Compression adjustable, see Post #328 by Lethal Performance or go to their website directly for details - Available Now
ISO 9001:2000R certified
32 way adjustable damping
Singe Cylinder Mono-Tube Design
3 Valving options utilizing 3 different shim stacks
Piston Rod Design
Front Camber Plates
Thrust Bearings
Sport Springs with less than 5% deformation (Swift also Available)
Independent Pre-Load and Ride Height
Aluminum bottom brackets
JRZ RS Pro Double Adjustable Coilovers - Rebound and Compression Adjustable (MSRP is 5400.00)
Available ?, ***SEE POST #268, Page 16, for a detailed break of all JRZ offerings***
12 clicks of compression
24 clicks of rebound
adjustable gas pressure
remote canister with a digressive blow off system
www.jrzsuspension.com
K-Sport Kontrol Coilovers - Height Adjustable and Rebound and Compression adjustable (36 way) (MSRP is 999.00), Available Now:
http://www.redline360.com/ksport-ko...4sugjkCIv3MPc9tDxafabUG5Pou-f5iCYaArC28P8HAQh
KW V1 Coilovers - Height Adjustable Only, Rebound and Compression are spec'd by KW and are Not Adjustable (MSRP is 1700.00), September Availability:
http://www.kwsuspensions.com/coilovers/variant1/
http://www.tirerack.com/suspension/...toYear=2015&autoModClar=GT+w/+Performance+Pkg
KW V3 Double Adjustable Coilovers - Rebound and Compression Adjustable (MSRP is 2600.00), September Availability:
http://www.kwsuspensions.com/coilovers/variant3/
Penske Coilovers (MSRP is 8995.00, doesn't include the springs - choice of either Eibach or Hyperco, custom length and spring rate), Available Now:
http://shop.penskeshocks.com/2015-Mustang-PAckage/
http://shop.penskeshocks.com/files/downloads/PR%2014.3%202015%20Mustang%207565.pdf (coilover specs.)
Penske / Full Race Motorsports Coilovers (MSRP to be announced): In Development
RideTech HQ Single Adjustable Coilovers - Rebound Adjustable Only (MSRP is 2400.00), Available Now:
http://www.ridetech.com/store/2015-mustang-coilover-level-3-clone.html
RideTech TQ Triple Adjustable Coilovers - TRUE TRIPLE ADJUSTABLE, Rebound, High Compression and Low Compression Adjustable (MSRP is 4750.00), Available Now:
http://www.ridetech.com/store/2015-mustang-coilover-level-2.html
Roush Single Adjustable Coilovers - Not a True Single Adjustable, Only Height is Adjustable, Rebound and Compression are spec'd by Roush and are Not Adjustable (MSRP is 1629.00), Available Now:
http://www.roushperformance.com/parts/2015-Mustang-Single-Adjustable-Coilover-Kit.html
Interesting side note…according to CJ Pony Parts, Roush’s Coilovers are based on or manufactured by KW - see the last paragraph on this page...http://www.cjponyparts.com/kw-suspensions-coilover-kit-v1-2005-2014/p/KWCK1/
Roush Triple Adjustable Coilovers - Not a True Triple Adjustable, Rebound and Compression Adjustable only (Roush counts height adjustablity as the third adjustable component) (MSRP is 2589.00), Available Now:
http://www.roushperformance.com/parts/2015-Mustang-Triple-Adjustable-Coilover-Kit.html
Stance Coilovers, ETA winter 2015 or early 2016
www.stance-usa.com
ST Suspensions ST-X Coilovers (by KW) - Height Adjustable Only, Rebound and Compression are spec'd by KW and are Not Adjustable (MSRP is 1300.00, but there site lists the price as 1104.99), Available Now:
http://www.stsuspensions.com/catalog/product/view/id/14123/category/4/
http://www.stsuspensions.com/coilovers/st_x/
http://www.tirerack.com/suspension/suspension.jsp?make=ST&model=X+Coil-Over&group=X+Coil-Over&partNum=STC13230065&autoMake=Ford&autoModel=Mustang+Fastback&autoYear=2015&autoModClar=GT+w%2F+Performance+Pkg
Vogtland Height Adjustable Coilover Kit, Available Now:
http://www.americanmuscle.com/vogtland-height-adj-coilover-kit-s550.html
Vorshlag MCS Single Adjustable Coilovers - Rebound Adjustable Only , (MSRP is 2650.00), Available Now:
http://www.vorshlag.com/product_inf...d=786&osCsid=0b48fc1b054ec680bff85f0f0212114d
Vorshlag MCS Double Adjustable Coilovers - Rebound and Compression Adjustable (MSRP is 3350.00), Available Now:
http://www.vorshlag.com/product_info.php?cPath=141_322_329&products_id=789
XYZ Super Sport Single Adjustable Coilovers - Rebound Adjustable Only, Availability, (from another thread, these maybe the same as k-sport coilovers)
http://www.xyz-racing.com/coilover.php?Key=148#Main
http://www.xyz-racing.com/model_spec.php#C696
http://www.xyz-racing.com/about.php
socalsnake
socalsnake
Earth
'15 5.0 GT PP
POOPonYOU
I Do Stupid Well
Paramount, Ca
2015 Race Red GT Premium
DUDE! That's awesome that you took the time to put this together. I don't remember where I read that Roush Coilovers were made by KW. Jay from Hypermotive said they installed the Roush coilovers on their cars and they really really like them.
socalsnake
socalsnake
Earth
'15 5.0 GT PP
I'm not positive that KWs make Roush's coilovers, but from the CJ Pony Parts description of the KW coilovers, it seems that KW may manufacture them for Roush or Roush uses KW parts. Whether they do or not, I guess it really doesn't matter since they are both quality products.
Are you looking to pickup coilovers?
POOPonYOU
I Do Stupid Well
Paramount, Ca
Yes sir, I was originally going to go with Steeda springs but I was told the ride quality is better with Coilovers. I was think KW or Roush. aFe and Cortex look awesome but out of my price range for my daily driven GT.
socalsnake
socalsnake
Earth
'15 5.0 GT PP
Yes sir they are expensive. Exactly why I'm wavering between options. aFe, Cortex and Ridetech look great, but I'm hesistant to drop that much coin on a daily driver that won't see the track.
KW or Roush look to be great. I can vouch for KW as I have purchased and used their products before and they performed outstandingly.
Are you thinking single adjustables or double adjustables for KW / Roush?...yet another decision lol.
POOPonYOU
I Do Stupid Well
Paramount, Ca
I'm going to go with the V1. I just want a good ride with even tire wear. Will I need camber plates to make the tires sit flat?
socalsnake
socalsnake
Earth
'15 5.0 GT PP
Yes, for the KWs, I believe you will need Camber Plates. Some of the other options like RideTech come with this type of adjustability.
Here are the best options for Camber Plates...
Maximum Motorsports (247.00 / pair)
http://www.maximummotorsports.com/Mustang-Caster-Camber-Plates-2015-P1480.aspx
Cortex Racing (349.00 / pair)
http://cortexracing.com/product/mustang-caster-camber-plates-for-coilovers-2015/
POOPonYOU
I Do Stupid Well
Paramount, Ca
socalsnake
socalsnake
Earth
'15 5.0 GT PP
Will I only need them in the front?
Yes only the front. Unless you're going really low like below 2".
I'm not going much lower than 1.5" front and a little less rear so I will only purchase front plates if they're not included with whichever coilover I decide on.
POOPonYOU
I Do Stupid Well
Paramount, Ca
I'm not going much lower than 1.5" front and a little less rear so I will only purchase front plates if they're not included with whichever coilover just I decide on.
It's funny that the cheapest priced option, BC, include camber plates with their coilovers but the more expensive options, KW V1 & Roush V1, do not. :doh:
Grim_Reaper
'Merica
United States
Dylon
2021 Mustang GT Premium California Special 10-spd
Also, the rear already comes with camber adjustment so nothing additional is needed. If you wanted complete control, adjustable toelinks and adjustable lower control arms would allow for further adjustment.
socalsnake
socalsnake
Earth
'15 5.0 GT PP
Impulsed7
HPDE Champion
Va Bch/Pittsburgh
Brad
EB PP track rat...
You should list whether each is progressive spring, linear, or has options for different rates.
