NEW TURBO KIT!!!!!! STREET SLEEPER!!!
Status
Not open for further replies.
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
Fake? I thought it uses stock airbox.
Also I would think the turbos mounted low would be advantageous. Not exposed to under hood temps, cooler air flow under the car, and splashes of cool water from the road during rain to keep the turbos cool.
We use the stock airbox.
We have developed our top mount kit to protect adjacent parts from heat etc. They both work really well.
gimmie11s
SoCal
Murica!
This is a great idea.
Im guessing its similar to the LPF kit using comp-style oil less turbos.
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
This system has multiple turbo choices. We send a cast wheel "sleeper" turbo standard, and we have options from us that include Precision, Garrett, and Borg Warner. The system has a state of the art scavenge system that installs easily and works better than any one one the market.
Team Hellion
Notagain
United States
yellow 2016 5.0 totaled white 2018 A10 now
This looks really promising. Maybe just maybe finally a sub 10k turbo setup from a reputable company.
ypena02
Massachusetts
2017 Mustang GT
How are the turbos lubricated? Does the oil pan need to be tapped?
HELLION TURBO
HELLION TURBO
United States
2015 Mustang GT
No sir!!! No tapping needed.
We re-enter the scavenged oil into the oil fill cap with a special fitting we send.
Super easy to install.
GT2
NEVERADA
NADA BRAH
Ya I would still be worried. I;ve seen what happens to hot metal when it gets hit with cold water...not cool. piece of mind I will stick with top mounts. Plus what the fun in hiding all that stuff... My car is already kinda obvious that its not stock and I want the screamer surge covers lol.
Not an issue. There's an effect that you can look up that describes the process when water hits a hot (1k~ deg) manifold etc (except it's been years since I looked this up so I can't tell you what it is, do enough tubular turbo manifold research and you can find it). It basically beads the water up and then between the bead and manifold there's a layer of really hot steam that keeps the two from contacting. The end result is, splashing of water like you might have on the street from rain etc shouldn't cause any harm. You might get surface rust over time, but that's just surface rust. Easy to clean and prevent.
It's only going to be a damage problem if you pile drive straight through a puddle. And if you drive through deep puddles willy nilly, you're risking a whole bunch of nonsense regardless if the car is modded or stock.
Ultimately bottom mounts again have been run on dailies for years. You should do whatever you want, but for the sake of the hoards of people who will read your concern and think it's actually a point of failure, it's nothing to be worried about. If you're really concerned cheap, easy steps can be made to prevent any such failure.
francisco511
Los Angeles
2015 Mustang GT PP
I spoke to them on the phone this morning. They said the cast wheel “sleeper” brand turbos can also be upgraded to ball bearing for 500$.
Ponderthis
Boost Loading...
Senoia, GA.
Chase
2015 GT Premium
Curious who makes these "sleeper" brand turbos..
GT2
NEVERADA
NADA BRAH
Team Hellion
Hate to be "that guy" but can you give more info about what the cast turbo specs are like? A/R etc or even just what model they're most similar to. I'm really considering this kit and would love to be able to make an informed decision between cast or upgrading to billet.
GT2
NEVERADA
NADA BRAH
From all the cars I've dealt with (mainly turbo supra etc) switching to BB rarely nets any increased throttle response over journal bearing. You have to remember, journal bearing is a piece of metal floating on a really slippery sheet of oil. It doesn't have a lot of friction.
Ball bearings do seem to be good for situations where you might have lower oil pressure, or different thermal loads... But ultimately when compared to upgrading to a billet wheel for example, it's not an upgrade worth doing most of the time.
sigintel
Ray
2018 GT
Leidenfrost Effect
https://en.m.wikipedia.org/wiki/Leidenfrost_effect
  • Like
Reactions: GT2
beefcake
Bethel
2018 Ford Mustang
Well be doing some fun with this kit on our new 17 project car, should be fun!
  • Like
Reactions: GT2
Z_Rocks
S.W. Fla, USA
Import
@Hellion;
Will this kit work with 2019 GT? This kit will be the main reason I'd buy a GT, instead of getting the EcoBoost, since I'm a Turbo guy.
Status
