2018 5.0L = Dual Injectors: Direct + Port = Confirmed
kn7671
Arlington, TX
2015 Mustang GT PP
2018 Mustang 5.0L - Dual Fuel Injection - Direct + Port = Confirmed
The new 2018 5.0L V8 engine has been confirmed to have dual fuel injectors, a low-speed port fuel injector plus direct injection.
For those that don't know, without port injection and using direct injection only, the engine loses the ability to keep the Intake Valve's clean, as the PCV system pulls oil and fuel vapors back through the air intake system. With the port injection added, you have fuel being sprayed onto the back-side of the intake valves. The fuel spray cleans and cools the valves, removing the issue that Direct Injection brought to engines.
Carbon build-up in the Intake Port and on the Intake Valve has been a problem for Ford and anyone else that designed their engines with Direct Injection only. Last information was that Ford has no approved procedure to remove the carbon build-up on Direct Injected only engines, thus the need for port injection in combination of Direct Injection.
GA
Damn. I should have wait for a Mustang.
B0SS603
@dib_5.0
Ft. Worth, TX
Jacques
2015 GT Premium Deep Impact Blue
At least you didn't buy a 2010 GT in 2009. :lol:
The next best thing is always better and brighter. You will always feel like you should have waited a bit more. Just think the next time you upgrade it should be even better than the MY 18, hopefully.
Blk2015GT
2015 GT
All other things aside it could theoretically add up to another 10% to 15% hp, so figure another 44 to 65hp.
So a 475hp to 500hp Coyote is possible. I would guess more on the lower end though around 475, as 500 would put it too close to the Voodoo.
MikeyV
Bay Area, CA
2014 GT Premium - Brembo - Race Red
I think the early 5.0 (2011) had an iron block? Could be wrong. But they've been aluminum for a while.
Twin Turbo
Super Moderator
Moderator
England
Paul
Mustang '05 GT
2010 GT500 had an iron block
2011+ GT500 had an aluminium block
Coyote aluminium since birth
airjonny
Columbus
'18 Ecoboost
What a time to be alive. The 3rd gen coyote is going to be a savage. We're probably looking at 460hp with no sacrifice to MPG? Sounds great.
