Found a good Oil Filter Wrench / First Oil Change
84venom
2000 Cobra R, 2016 GT350 TP DIB w/White Stripes
Seems to be common for the oil filter to be cranked on pretty tight from the factory. This, coupled with the close quarters placement, can make it quite a challenge to remove. I found the perfect filter wrench at NAPA if anyone's interested. It helps to puncture the bottom of the filter too....
[/url]0331161451a by Performance Restoration, on Flickr[/IMG]
[/url]0331161452 by Performance Restoration, on Flickr[/IMG]
[/url]0331161435 by Performance Restoration, on Flickr[/IMG]
[/url]0331161257a by Performance Restoration, on Flickr[/IMG]
GT_Dave
NE Illinois
1970 Mach 1 408EFI , 2016 GT350
Here's a tip for those having a problem getting the filter loose. I have one of those tools and it still was hard to get a good grip on the filter. So I took a piece of notebook paper and fit it between the filter and the wrench. Worked great and made it easy to break the filter loose, a paper surface has 7x the coefficient of friction than steel on steel.
stang302
2016 GT350
Good find. No slippage? Torque specs on filter are 17 ft-lbs or 23 n-m which would explain why they seem pretty tight. Probably for vibration resistance.
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Plastic bag around the oil filter when removing it is a neat trick too . :thumbsup:
84venom
84venom
I see we have the same Engine Assembly team. I just noticed from your photos! :cheers: John
Very cool, that explains why ours are the fastest!! LOL. :headbang:
84venom
84venom
That's an excellent factoid, thanks for the tip!!!
Rainier42
Bucks County, PA
2019 Performance Blue GT350R
Thanks for the tips and photos, my first change coming up in 250 miles.
arsenalrocks
GTA
2016 GT350
i m going to try to drill a hole next time and let it drain out for 5 mins.
