Picture(s) request: regular GT350 with FP lowering springs and 30 profile tires
fpa1974
GA
'19 GT350R
I am trying to see visually how this combination looks and if possible some measurements of ride height.
Thanks a lot!
Mjc1241
Georgia
Reese
2016 Shelby GT350
Nice. What size rims are you running?
stanglife
Jeff
1993 Coyote Coupe
Damn that looks nice.
fpa1974
GA
'19 GT350R
Thanks guys, sorta full stats, they are Satin Bronze Forgeline VX1Rs in R spec 19X11 and 19X11.5. I can never remember the offsets though. They are around here somewhere.
Thanks for pics. Is it just me or PS4S’s seem wider than MPSS’s? I know these are different sizes but the front tires seem to be more square profile. Also what camber do you run up front? Any issues with rubbing the strut?
Minn19
Minnesota
Jason
19 ZL1 1LE, 19 F150, 19 SB S5
Next spring I should take a pic of the stock rear 305 PSS vs the front 305 PS4S to see. But yah I agree, I think they do have a squarer look to them over the PSS.
Also stock camber and no rubbing issues.
fpa1974
GA
'19 GT350R
Stock camber should be fine. I am running -2.8 in the front and it runs very close to the strut (no rubbing at all but if the tire were a bit more square probably it would - on the other hand 30 profile has shorter sidewall so that might compensate)
16GT350
17 GT350
Got mine on Nitto 305/30 series. Love the difference in every way...
GTthree50
San Francisco Bay Area
Magnetic Grey 2017 GT350
I have to say I am envious. The lowered stance looks great but there is no way I could drive mine around on a lowered suspension without replacing my splitter every week. Air bags would be the only real option for me to get an aggressive ride height but clear speed bumps and get in and out of my own driveway. No chance I'll dump my magneride though.
Relak
Silver Spring, MD
2017 Shelby GT350 - Oxford White
I agree. Only reason I've lowered cars in the past is because they often come from the factory looking like SUVs. IMO I find the stock GT350 height to be perfect and the ride quality is pretty damn amazing with magnaride.
betterthansx
Ontario
GT350 (looking for)
It depends on everything.
If you run a wider wheel, you will get a squarer profile on the tire. If you run a narrower tire and a wider wheel, you will get a rounder profile (stretch).
From what I have seen, the PS4S are very similar to the PSS but the shoulder tread is more similar to the PSC2. The shape of the sidewall doesn't seem to be much different, or different at all.
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Some pics from an event last weekend
Front-ish profile
Neutral-ish load from side
Outside from side
Same load but from inside perspective
jefc73
Detroit, michigan The Motor City
Jeff GTFO_0019
2017 GT350R
that looks awesome. Love the ride height. Just not sure I want to do that to my R.
