Good point. Looking for experience with drive-by (pass-by) measurements. Microphone placement varies per track, so just trying to get a general feel.Measured at what distance?
Right at the exhaust it's going to be significantly higher, but if they are measuring at the walls of the track (which could be 50m away), it would be a lot quieter but probably pretty close to those numbers.
Lifting is no fun....you know that!!Old school, lift off the throttle when passing by microphone.
You can use the Grimmspeed exhaust valve delete plugs (buy two and it's much easier to buy and use with the extension cables) to disable the exhaust valves so they stay closed.
Good to hear. I was there Sunday.Update: ran at Laguna Seca on a 90db day. Passed no problem using the Grimmspeed modules. Note that sound db is dependent on lots of variables including distance from the sound meter and even things like cloud cover that can make the sound seem louder. So just because I passed on this particular day does not mean that a different car on a different track would make a 90db limit...or even if I would pass on a day with low clouds. What I do know is that it would have been very unlikely to pass sound if the car was not kept in quiet mode.
