5.0Nasty
The MGW mounting system is designed so that ...
1. You do not mount using bolts that are designed for the cross member.
2. gives you the ability to use a REAL driveshaft safety loop like the BMR one.
3. The triangular design is superior because it not only supports the shifter vertically, but actually causes vertical loads to actually be shared horizontally as well.
The race spec also uses a trunion design that allows the fore and aft to be shortened without the side to side to be shortened the same amount. To my knowledge, Barton and MGW are the only companies that offer this.
George
Is there any forum discount offered for MGW?
