Broke the front mounts on my differential tonight at the track
lxh89
Dallas, TX
2015 Ruby Red Mustang GT - Whipple Auto
So took a trip up to Northstar Dragway in Denton to test out my new Baer drag brakes. I only got one good pass before all hell broke loose. On my second pass, car hooked insanely hard then around the end of the 60 it sounded like Id broken the driveshaft.
Got towed home and put up the car on jack stands and found this - front mounts were sheared completely! The other thing I noticed, the pinion flange where the driveshaft connects slung some kind of grease. Not sure if the driveshaft is fubarred but I'm definitely gonna need a new differential housing.
I'd heard the differential bushings could lead to this so can't say I'm very surprised but didn't think it would have at the 700rwhp level. I was thinking these cars making 850+ were doing this kind of damage.
Tony
z06psi
Evans, GA.
Andrew
The pot stirrer
This isn't the first auto diff to break. Get a stock manual one as they are iron.
The grease from the driveshaft is coming from under the cover where it bolts into the flange.
lxh89
Dallas, TX
Yeah, I ordered a 3.55 diff and an automatic flange to convert it.
Thanks
lxh89
Dallas, TX
Got the differential pulled out and looks like the end of the drive shaft that connects to the diff flange has some kind of universal ball joint. Well, it's totally fubar and spins. That explains all the grease getting ejected from it. It also explains why the car wouldn't move in forward or reverse.
So new driveshaft now too...
I think the pinion bearing took some of the brunt too because there's considerable end play when I pull/push the pinion inside the diff housing. It feels kinda sloppy upon turning. Everything else looks fine.
Tony
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Well at least you know your making good power. Broken parts are a part of the game. Good thing is everything can be fixed!!
What does it look like inside the diff - have you checked yet?
I wonder if the ring/pinion sheared teeth...
BMR Tech
Tampa, FL
www.bmrsuspension.com
Dion
Welcome to the club.:headbang:
lxh89
Dallas, TX
I didn't open the housing. The gears move free. I think it's just tore up the pinion bearing based on the end play slop.
It usually takes a lot more to break an 8.8 gear set. Spider gears typically break first then the resulting metal pieces get caught between the pinion and ring gear causing more damage.
Tony
Dominant1
Dr Frankenstang
Ford performance iron differential with 3:55 traction lock gears $899..
lxh89
Dallas, TX
Don wood ford has them for 790.54. Thats where i got mine. Ordered last saturday and got it yesterday.
Really nice folks to deal with too.
Fordracingpartsbydonwood.com
lxh89
Dallas, TX
Got everything back together tonight. I got the last piece today, a shaftmaster's driveshaft.
I got it in, took the car for a spin and first thing I noticed was a clicking noise coming from the left side of the vehicle. Took it back home, pulled the rear wheels, pulled the axle nuts and re-torqued them. Put it all back together and clicking still there on left side.
So took it for a highway run and get vibration at 60mph. Got it up to 100 and the vibration is ridiculous. So I'll try re-clocking the driveshaft. Kind of annoying but seems to be a thing with the s550 driveshafts.
I ordered a stocker off ebay to have as a last resort in case I have to RMA this one.
The good news is, the new differential with the 3.55s is smooth as silk with zero whine.
Tony
Jeff_oddo
Colorado Springs, CO
Jeff
Mustang GT Premium
Did you have diff lockout bushings or just stock ones?
lxh89
Dallas, TX
Diff lockout bushings...steeda
Jeff_oddo
Jeff
Mustang GT Premium
Upgraded hardware? I have the Steeda ones with the BMR upgraded hardware.
