Bartly
Hello, hoping someone can remember something from their install. I've got got the Stage 2 PC kit on my car and am installing a new crank pulley bolt. The kit came with a 120mm long new bolt and when I installed it originally I omitted the large flat washer that was installed on the bolt from the factory. The reason I'm now replacing the bolt is that it came loose and I was half guessing I should have had that thick washer installed to help with the bolt's stretch, don't know how valid that thought is, but it crossed my mind that it could have something to do with the bolt coming loose. Anyway, was in the process of installing it and see without the washer, looks to be just shy of 3/4" thread engagement into the crank. The flat washer measures 5/16" thick. So with the washer there is only going to be 7/16" of engagement which is less than the 12mm bolts diameter. From what I recall a bolt should have at least it's diameter of engagement?
Do any of you remember if you used the washer or not? I really don't want to end up without enough thread in my crank when I go to torque it down.
Thanks hopefully.
Thanks hopefully.
