CJ Pony Parts
- Dec 21, 2015
- Harrisburg, PA
- Website
- www.cjponyparts.com
- A large variety of Mustangs across all generations
Set of Four HRE 18" x 10" Tarmac FF15 Wheels for 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016 and 2017 Mustangs.
We managed to dig up one more set of these. This will be the last set of 18x10" HRE FF15's in Tarmac available, possibly anywhere! These are brand new in the box and have never been mounted or even test fit.
CJ's Low Price: $1,200 (MSRP on these is $2,300)
HRE designs and engineers their wheels to the highest standards and everyone knows that. And their new line of FlowForm wheels, including these FF15 wheels (15M810040033FB), is no different. The FF15 wheel features a slim 15 spoke design that will give your Mustang a sporty, yet elegant style. It comes in a sleek tarmac (satin black) powder-coated finish that will match any color Mustang. These wheels include center caps that feature the HRE logo and carry TĂśV, VIA, and JWL certifications.
HRE uses a unique manufacturing process called flow forming to construct the FF15 wheel. Flow forming takes an initial solid cast of the wheel and then stretches it over a mold by spinning the cast while applying heat. The wheel that is produced by the flow form process is stronger and lighter than regular cast aluminum wheels by improving the grain structure of the wheel during the flow form process.
Wheel Information:
- Size: 18” x 10”
- Lugs: 5 x 114.3mm (5 x 4.5”)
- Finish: Tarmac (Satin Black)
- Backspacing: 7.07”
- Offset: +40mm
- Center Bore: 70.6mm
- Weight: 21 lb.
- Center Caps: Included
- Lug Nuts: Included (2015-2017 ONLY)
Recommended Tire Size: 285/40-18
This wheel is ONLY available as a set of four wheels.
Tech Tip: This set of wheels are NOT intended for use with 2015-2017 Shelby GT350 and GT350R model Mustangs.
Tech Tip: Although we recommend picking up a set of small diameter lug nuts, these wheels are compatible with the factory lug nuts found on all 2005-2014 Mustangs. HRE does include a set of lug nuts, but these are specifically for the 2015-2017 Mustang and the larger wheel studs that they are equipped with. The included lug nuts cannot be used on the S197 platform.
Please Note: The offsets and tire options for these wheels are very aggressive. It is highly recommended that you have all of the proper equipment necessary so that your vehicle can have a perfect alignment done by a professional in both the front and the rear of your Mustang.
*Each set of 18” wheels may require a pair of Steering Rack Limiters (P/N: HW2869) on 2005-2014 Mustangs ONLY.
*Valve stem TPMS compatible. All 2007 and newer Mustangs use tire pressure sensors in each wheel.
*This 18" wheel kit will clear all available brake kits found on any 2005-2017 Mustang.
Order this Set of Four HRE 15M810040033FB 18" x 10" Tarmac FF15 Wheels for your 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015, 2016 or 2017 Mustang from CJ Pony Parts today!
These will NOT last long at this price!
Wheel Information:
- Size: 18” x 10”
- Offset: +40mm
- Weight: 21 lb.
