GT350 FORScan Tweaks
Spart
Iowa
17 GT350
my hazards work fine so does my traction control. the exhaust is changed through the track apps for a track pack gt350 that still works fine. Thanks for the heads up! if you could get me in contact with the guy you know who has the GT350 bezel that would be great! thanks!
The hazards probably aren't working "correctly" unless you do the FORScan fix. You'll notice that you have to hit them twice to get them to turn off or on. That's because the premium bezel is setup as a momentary switch and it stays in the up position when you turn it on.
I'll send you a PM with the name of the other member.
JJones
Omaha
2015 s550GT
do you know what needs to be changed to make them work? thanks for the help!
Spart
Iowa
17 GT350
I have a 2016 Track Pack car and upgraded to the 8" screen using factory Ford parts from OEMRadio (Jesse, here on the forums). Early on, nobody knew what figures to enter in to activate the toggle on the new bezel. That is no longer the case. You have to have the factory 8" bezel and once you do the new toggle can be activated.
Are you talking about the Exhaust toggle specifically? If so, I don't see that listed on the GT350 spreadsheet, mind sharing what needs tweaked? I'll add it to my post on what to change when doing the swap.
Epiphany
Epiphany
Global
I like to disassemble things.
Yes, specifically the exhaust toggle on the premium bezel that was used on Tech Pack cars with the 8" screen (or R models so equipped) as well as post '16 cars that had the larger screen.
I didn't figure out the changes necessary but rather a gentleman I know from Canada did. He spent quite a bit of time on this one and nailed it. As much as I want to share the details - I can't. Suffice it to say, the 8" swap I did into my '16 Track Pack using Ford hardware and the larger opening factory bezel has had a fully functioning exhaust toggle in action for over a year now.
IPC 720 06-01 7F6D 9664 9X
Where X needs to be:
"E" for exhaust mode switch enabled
"C" for the Track Pack/Base model with no exhaust mode switch
Spart
Iowa
17 GT350
Thanks, I'm going to add that to my post about FORScan mods when doing base to 8".
kartguy898
Ottawa, Ontario
2016 Shelby GT350 / 2016 F150 FX4
Has anyone seen a Forscan code to change the daytime running lights to use either the parking lights or the 3 /// lights (vs. the headlamps)? Saw something on FB that someone did it, but nothing to back it up.
Spart
Iowa
17 GT350
Puffin
2017 Shelby GT350 Black W/ Blue Stripes (H4044)
Can you post a pic?
ryanr24
El cajon
2016 gt350
Trying to get the mx WiFi connected via iOS app, and it keeps saying command time out... any suggestions?
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
That’s too bad about the valves, I was really hoping it would be simple.
r1racer
murica
GT350
So OP are you going to edit your original post and list all of the changes? 23 pages of sorting through is a bit much...
comm
EU
Vaclav
GT350
Hello guys,
I'm still waiting for my OBDLink MX Bluetooth (I live in EU), but I already downloaded Module Build Data. I'm replacing US SYNC 3 with EU SYNC 3 (otherwise EU maps doesn't work). EU SYNC 3 comes with Base Mustang logo (animation), I already saw it in another car, so I'll need to change it to GT350 animation. This is the only thing I want from it :)
What my Build Data says:
7D0-02-01 4341 0702 C027
What I found here on the forums:
7D0-02-01 5553 0602 C04A Mustang GT Nav Anim.
7D0-02-01 5553 0702 C04B Gray GT350 Nav Anim.
7D0-02-01 5553 0902 C04D Red GT350R Nav Anim.
So after replacing SYNC 3 unit should I change only 0702 column (it will be probably 0602), or everything else as well (4341 and C027)?
Thanks ;)
EDIT: So I changed only 0702 column and it works - so there's no need to change anything else.
rb92gt
Ponte Vedra, FL
2016 GT350 Cooled Tech
GT350 Forscan Summary
Hello guys,
Thanks ;)
Change the entire line. If you need help read this summary I made:
https://www.mustang6g.com/forums/showthread.php?p=1506523
:cheers:
kommons
California
GT350R
I'm trying to experiment with the idea of adding fogs to the GT350. I bought a headlight switch with foglamps but the bcm needs to accept the can bus message. I'm curious if it would even have the necessary relays to activate anything. Has anyone discovered how to make this change in Forsscan at least?
