Brake upgrade (EradiSpeed, Steeda hosts, and Motul)
Bull Run
AZ
2015 Mustang EB Prem PP
Next upgrade on my list were the brakes. I initially mulled swapping the EB PP 4-piston calipers with either Baer Drag Race Brake kit or Brembo 6-piston calipers, but decided not to for the following reasons:
Baer Drag Race Brake kit: It's about 60 pounds lighter (for both sides) than the stock brakes. That's greater weight savings than my previous light weight wheel upgrade. However, it comes with tiny calipers, pads, and 11.62" rotors. According to Baer and some forum posts, race pads that come with the kit are adequate enough for repeated stops associated with street use, but they are very noisy and dusty. You can get street pads for the kit but they are more prone to fade. This kit would've been awesome for a drag racer, but not ideal for street use.
Brembo 6-piston: If I had the base EB with two piston calipers, I would've just gone with the Brembos instead. I did some research and found that 4-piston calipers on base GTs and EB PPs are good enough for track duty with fluid and pad upgrade. I never felt that EB PP brakes were weak so I decided to stick with those.
Bull Run
Bull Run
AZ
EradiSpeed Rotors
First thing I did was to swap rotors out with EradiSpeed 2-piece units for weight savings.
Front rotors
13.9" OEM w/ 20K miles: 28.4lbs
14" EradiSpeed: 23.8lbs
Difference of 4.6lbs each or 9.2lbs total for front
Rear rotors
13" EradiSpeed: 13.0lbs
13" OEM w/ 20K miles: 17.1
Difference of 4.1lbs each or 8.2 lbs total for rear
While my main goal was weight reduction, they do look much better than the OEM rotors.
Bull Run
Bull Run
AZ
Steeda Stainless Braided Brake Lines
My car's almost three years old, so I decided to upgrade the brake hoses while I'm doing the brake fluid flush. I liked how the hose upgrade felt on one of my past cars, so I decided to go the same route with a set of Steeda Stainless Braided Brake Lines.
Stock brake hose
Steeda brake hose
Side by side
Steeda hoses look much better and feel more solid over the stockers.
I had issues with both of my rear hard line flare nut threads. Fortunately, I was able to put stock hoses back on and drove to a shop to get them tapped. Search on the Internet showed that I'm not the only one with this issue, so keep an eye out for this when you are swapping your rear hoses.
Bull Run
Bull Run
AZ
Motul DOT 5.1 Brake Fluid
My original plan was to use Motul RBF 600 brake fluid. However, research showed that racing brake fluids have higher viscosity and can interfere with ABS and TC. Since my car's a DD, I went with Motul DOT 5.1 with low viscosity formula for ABS use. While it's dry boiling point (516F) is lower than RBF 600 (594F), it's still an upgrade from DOT 4 minimum standards (446F).
Three 500ml bottles should be plenty for a flush.
Bull Run
Bull Run
AZ
Driving impression
I went through the second part of the rotor seasoning process today. It consisted of four stops from 60 to 15 MPH at 50% effort, again at 75% effort, then six hard pedal stops (without triggering ABS).
As expected, stainless steel braided hoses provided a slightly firmer brake pedal feel with less pedal effort required to slow down.
Even with stock pads and repeated braking, I never felt any brake fade and was able to bring the speed down each time with confidence.
I didn't do any brake tests with my stock setup for comparison, but I found an article that showed that EradiSpeed rotors were good for reduction of about 10ft in braking distance and had better fade resistance over stock 13.9" rotors. The article also has a step by step directions on how to do rotor swaps if you haven't done one before.
Chef jpd
Brooklyn, NY
Great job.
Now it's time to paint or powdercoat those calipers to look as good as those rotors.
Optimum Performance
Gold Sponsor
Titusville, Florida
www.facebook.com
Tommy
'15 GT PP
Stock brake hose
Steeda brake hose
Side by side
Push that piece of rubber hose up to the frame mounted fitting on the front hoses. It's purpose it to keep the hose straight and out of the way.
DUNDEM
Miami
2015 Base EB PP
Awesome write-up and reasoning behind each mod! Thanks man!
Agreed. Great write up. The 4 pistons are plenty good for the Ecoboost in my opinion. I have DBA slotted ones and they are good but I think I’m gonna going this route when it’s time to replace them.
Cost & part #s for rotors?
Bull Run
Bull Run
AZ
xXANCHORMONXx
SF CA
2016 GT350 Track Pack
For anyone who does a lot of track use I would advise against the Baer 2 piece rotors. They are 2 piece but they are not a true floating 2 piece design. This means that has the steel disc and aluminum hat heat and cool there is a possibility of cracks which happened to me. For a daily or for good looks they will do the job.
I know girodisc and AP Racing are a true floating setup.
