GJarrett
FP tune, catch can, cp-e intercooler. Check my sig line for full list of mods.
At 27k miles my EB started a severe shudder/shaking in 6th gear when accelerated uphill from low rpms. I can cruise at 55-60mph in 6th gear, then floor the go pedal, and the whole vehicle will shudder until it speeds up to a higher rpm when it will smooth out. The whole vehicle will shake, initially feeling almost like an out-of-balance driveshaft or bad u-joint or something. It is NOT the 50-70 mph vibration problem. It only happens under load - I can get it to do it in 5th gear too it's just a lot more significant in 6th - it does not happen at high rpms or when it is coasting. If I wind out the engine without lugging it, it purrs like it's supposed to.
No CEL and no codes thrown.
BTW, I KNOW I'm not supposed to lug the engine but something is wrong and it needs fixed.
I took it to my dealer's service department and they too felt like it was a driveline issue, they called the regional Ford engineer and his long-distance diagnosis said it was the 50-70 mph vibration, but he didn't ride in it and I knew this was different.
I asked them to scan it (just in case) in order to cross off as many possible options before throwing parts at this problem. The service mgr agreed and wanted to do what he called a Mode 6 scan while riding with me and watch the engine on his computer.
The scan tool would not recognize the car because I had the FP tune installed, so I went home and reflashed the car back to stock tune and filled up with 87 octane. I immediately noticed the shudder was not nearly as bad with the lowered power but it was still definitely there and at reduced severity I could tell that it seemed to originate up front of the car. My hopes rose that it was in the engine and would be something they could scan and identify.
Yes and no. The scan tool recognized my Mustang, we went for a ride with the service mgr in the passenger seat looking at his computer while I hit the gas at low rpm going uphill in 6th gear. Bingo, all four cylinders showed misfires until we sped up to higher rpms and it smoothed out again. So it's not driveline related after all.
I am familiar with the spark plug threads here so my first thought was plugs. I buy a set, go home, and pull my plugs. They looked fine, gaps are all good, but just to make sure I replace them with new plugs. The problem is still there. My service manager is stumped and it looks like he wants to keep it awhile to study it. I'd prefer my car has a short stay to get a known problem fixed quickly, not leave it at the dealer for who knows how long.
So it's not a coil or a plug, it's something that affects all of them. In digging through searches I found what may be a similar problem with F150 EBs having a condensation problem in their intercoolers. The intercoolers work so well that in humid conditions they condensate water that gets sucked in the intake to cause the shuddering. The fix seems to be drilling a small 1/8" "weep hole" in the bottom of the intercooler to let oil/condensation water out. Has anyone heard of this in our Mustangs? I really don't want to drill a hole in my intercooler.... or would it do no harm, so what-the-heck give it a try?
Does anyone have any possible ideas what the problem could be, or helpful suggestions where to start looking?
EDIT: SOLVED See post #62. I you are experiencing my problem, have your dual mass flywheel checked.
