15gtRob
I want the impossible and I think it can be done with an adjustable suspension. I want 60' times in the 1.5s but still have a car that is capable of handling around a track. I want to swap tires and make some suspension adjustments and have it hold its own at Auto X or Road Course.
Setup is as follows. Novi 2200 with Vortech BAP, ID1000 injectors, 3.8" pulley, Stock air box, stock headers, MBRP Street Cat Back, Mcleod Aluminum Flywheel and RST Clutch, Shaft Masters Drive Shaft, DSS 800 Axles, BMR SP080 springs, Race Stars with M&H up Front, MT ET Street R 305/45/15. I've tried running the tires @ 16PSI cold, 18, and 26. at 16 PSI I had massive tire shake during burnouts below 6500 and if I tried launching at 4500. If I held the engine around 7K during burnout tires wouldn't shake. Had to leave the line about 6k and sometimes it bogged other times it spun a little. The car makes just under 600 Wheel and I think it can run deep 11s. I just need to figure out a working combination. I'm running 1.8 and 1.9 60' consistently and thought the addition of bias ply tires with lighter wheels and clutch that doesn't slip would bring me deep 11s. Don't know if I need a driver mod or parts mod.
