HELP MANDERS Fix His Clunk
Manders Mustang
Manders Mustang
The Boss
Birmingham - United Kingdom
2016 Race Red Ecoboost
Video of clunk please Steve.
at work ill send u it on fb lad
[MENTION=33088]Scooby67[/MENTION] you sound like you may have the same issue of me it's like a thudding sound?
Manders Mustang
Manders Mustang
The Boss
Only time I had that on a car was with none standard wheels the spacer had corroded and partially broken between the hub and wheel casting .
I'll remove and check I didn't leave it in there....
Scooby67
Oxfordshire
Ford Mustang GT, shadow black.
The noise does vary slightly, when going over a long stretch of rough road it sounds more like a metallic knocking but when going over speed bumps it's more like a thud. Vary strange and very annoying, you would think it would be easy to spot as you would think something is broken but nothing obvious stands out.
Chappers
Sutton Coldfield, UK
Greg
Toyota Supra MkV - Tungsten Silver
Mine does the same, I’ve never really taken the time to find out what it is but it drives me crazy sometimes.
Yeah it's a bit annoying and embarrassing when you've got mates in the car and it's already creaking haha, my brakes squeal terribly too which is equally embarrassing...
Manders Mustang
Manders Mustang
The Boss
You got facebook? Join mustangs unleashed I've posted the video there; or just add me.
Scooby67
Oxfordshire
Steve i just watched your video and yours is a fair bit different to mine, mine sounds more like something is loose and sounds more metallic, yours is definitely more of a thud than what mine is.
Manders Mustang
Manders Mustang
The Boss
Odd... nobody seems to know what this is, many suggestions but really, it's going to my routes of either bore, steeda bits, or worn bushing.
hinch
uk
Sideways
one thing to note if you've changed sway bars or majorly lowered the car it can bend the sway bar end links especially the front ones this can lead to the odd clunk mainly the front end link banging against the front end suspension assembly on rear its less pronounced.
manders as for your link take car to nearest mot station and ask them to stick it on the suspension test machine and bounce the rear end around see if it does it when stationary and just energy being put into suspension or see if its the car has to physically be at an angle for it to happen
Manders Mustang
Manders Mustang
The Boss
Do all MOT stations have this? if so that sounds like a good first port of call.... I somehow feel most just put the local lacy in the boot and jump up and down?
hinch
uk
Sideways
i believe they should all have it its usually the same rollers they use for the braking efficiency test almost certainly quickfit should be able to bounce it and i think formula 1 centers have the gear too.
Brian V
USA Retired
Native Earthling
2015ecoboost premium 201A Nav Sec Race Red
Did you put the Steeda rear differential insert bushings on the rear diff ?
If so you are hearing the rear differential every shift .
SteveS
...Bon Scott Land...
Bon Scott Land
Mustang GT Magnetic
My rear suspension creaks when going up drop kerbs or slightly raised uneven ground, like a multistorey carpark ramp wonder if it's related haha
Mine too...thought it was just me! Seemed to coincide with fitting Eibach sway bars however it may have been doing it before and I just didn't notice.
hinch
uk
Sideways
have you all got cb005 fitted and/or steeda diff inserts ? in combo the bushes seem to creak put some silicone lube on all of them like proper over dose on the stuff and you'll find it'll go away.
simple test get hose pipe and squirt water all over your rear end if the squeeking stops you need more lube :)
SteveS
Bon Scott Land
Mustang GT Magnetic
I have the CB005 with the Steeda IRS alignment kit, but not the diff inserts.
Thanks for the hose/lube tip. Will be giving that a go for sure :thumbsup:
