GT350 front & rear brake pad replacement, Carbotech brake pads & Titanium shields
VoodooStang
View attachment GT350 Front Pads.pdf
View attachment GT350 Rear Brake Pads.pdf
Tools needed to remove rear caliper emergency brake spring
E-brake tools
JB Tools
OTC 6722 Brake Spring Locking Pliers
Lisle 40750
Parking brake cable remover
Compress as much of the e-brake spring as possible, makes the cable easier to slip off the lever
Carbotech front pads w/titanium heat shields, bottom pads are factory
Heat shields fit perfectly
arsenalrocks
GTA
2016 GT350
thank you!
JT1
PA
2017 GT350
Thanks! Glad to see the rears are so easy.
I know there are lots of ways to do it, but I think i might like the caliper spreading tool shown. Do they give the P/N?
VoodooStang
GT350 6-piston spreader tool, front or rear calipers
GiroDisc
Caliper piston spreader
Part Number PST-01
use on most 2, 4, 6 and 8-piston calipers.
VoodooStang
Titanium heat shields for front calipers
DocWalt
SE PA
GT350
Do you happen to have the number for the Ti rear shims? Hard Brakes has choices to select the front & rear GT350 setup, but they don't have any part # actually listed under the selection.
JT1
PA
2017 GT350
That tool inst very good. I tried it.
I read this 1/2 hour after I ordered it from Amazon. Is it usable but not ideal? Or should I try to cancel?
VoodooStang
Lisle pad spreader
I use mine regularly. No issues.
VoodooStang
Use the contact form to get in touch with Hard Brakes. I think they have used their stock up is why you don't see a part #. Had the same issue when I ordered my fronts. Had to wait approx 2 weeks.
firestarter2
NYC
RR G350 Track
There seems to be some quality control issues. I sent mine back. Maybe you will get lucky
EF300
The Swamp, Central FL
2017 GT350, 2020 GT500 CFTP
What did you do with the rotors with these pads. The manufacturer says you essentially need to resurface or replace the rotors if you're swapping in these pads.
