Procharger GT350 Intake Manifold/TB
cpelaez1
Silver Spring, MD
Cristian
2016 Shadow Black 5.0 Vert
Hey everyone,
I'm going to be installing a procharger P1 Stage II kit in a couple of weeks and have it Lund tuned. I'm currently running the GT350 intake manifold, throttle body, GT350 JLT CAI, and full exhaust. I'm on a Lund flex fuel tune. I was wondering if anyone on here had any pointers for the install with the 350 mani/tb. Also, does anyone know if I will need something else that won't be in the kit to make this all work? I'm not sure if it is any different from the manual.
Thanks.
Cristian
wildcatgoal
@sirboom_photography
TBD
Don't see why it would be any different except you'll need to find a way to connect Procharger's air inlet to the larger GT350 TB. Frankly I'd go back to the stock TB with an adapter - easier to achieve better driveability with the stock TB but Lund, I'm sure, can figure it out. Certainly Ford Performance can't for some reason... but I digress.
As you know, the vacuum lines on the GT350 IM consolidate to one coming from both sides of the engine, where on the OEM GT IM they stay separated until the connect to the inlet pipe downstream from the air filter and before the TB. So if there's a need, you can split the vacuum line on the GT350 IM or use a vacuum plug, if this is even an issue at all.
cpelaez1
cpelaez1
Silver Spring, MD
Cristian
Thank you for the tip. Lund has the tune ironed out really well right now for me. They said it won't be an issue with the procharger.
wildcatgoal
TBD
I think the Procharger piping is some kind of plastic. Maybe it can be heated a little to carefully expand over the larger GT350 IM. Might as well as Procharger... maybe they have some kind of adapter recommendation.
Crackerjack17
WV/Maryland
2017 GT PP
It's a silicone hose to the throttle body. And hey, you are only a couple hours from me, I'd like to see how your gt350 manifold runs compared to mine sometime.
cpelaez1
cpelaez1
Silver Spring, MD
Cristian
Yea sure thing. Did you install yourself?
venumous
PA
16' Procharged GT
I have the GT350 with stock TB and adaptor. I can let you know how the vac lines run. That's the only difference, took me one trial to figure out only vac was going to the purge valve the first start, you don't want to do that.
cpelaez1
cpelaez1
Silver Spring, MD
Cristian
Did you install the blower yourself?
venumous
PA
16' Procharged GT
Yes I did.
cpelaez1
cpelaez1
Silver Spring, MD
Cristian
Yes I did.
How difficult was it? I'm pretty nervous about attempting to install this lol. I'm trying to install it with someone who has done it before but I can't find anyone.
Andrewg
Sun, Sea, Sand and Camels
Dubai, U.A.E.
Andy
2015 Guard Metallic GT 401A
Did my Procharger install for the first time about 3 weeks ago. It was relatively simple and i'm no expert by any means. Getting at the bolts for the fascia removal is a pain. Worth buying an electric screw driver with an angled end just for that. Trying to catch all the coolant from the hoses whilst doing the thermostat housing swap was messy. The crank bolt was a bitch. Had to call a guy with an air impact as my electric impact was too big to fit even after removing the fans. Lots of time spent trimming and test fitting hoses. Also the supercharger itself needed to be clocked a small amount to fit properly and i didn't have a metric set of allen keys so had to wait till the store opened. It's actually pretty easy. Set aside a couple of days and take it slow and you'll be fine.
venumous
PA
16' Procharged GT
It was cake compared to other things I've done. Lots of experience working on cars.
cpelaez1
cpelaez1
Silver Spring, MD
Cristian
Crackerjack17
WV/Maryland
2017 GT PP
You wanna help me install mine haha
Yeah, I could, but it might be tough matching schedules, etc. What's your timeline?
