Crackerjack17
- Sep 22, 2016
- WV/Maryland
- 2017 GT PP
So I've been chasing knock or false knock ever since installing my longtubes. Intermittently I would see +3 to +4 here and there usually around 3-4k. And lately it has been running great but seeing knock between fast hard gear changes. Last couple of days I've been seeing knock on light throttle, but under wot, no knock and ran great. But tonight, consistent knock starting at 3k light throttle and right to +10 when trying to give it full throttle. Way down on power obviously. Gas is 93 sunoco with octanium. But here's the thing... idles fine. Quiet. Good vacuum at idle and part throttle. Oil pressure normal. Oil level fine. Neutral revs ok, but does maybe seem a little slow to rev. Doesn't seem snappy.
So what should I check? I'm going to pull the plugs and do a compression check? Pull supercharger belt and make sure procharger spins freely. Think maybe a ring is damaged? What you guys think?
