Ferodo Pads and more for your 15+ GT350
Status
Not open for further replies.
GT350Brakes.com
Northern California
Tony
GT350 TP
We have Ferodo street and race pads in stock and ready to ship for you 15+ GT350 and 15+ GT PP.
Ferodo is a top name in the racing world and supplies many car manufacturers with oem pads. Each compound has their benefits but our biggest one is that you can swap between each pad without re bedding.
Please follow the link to our website and be sure to enter M6G for a special forum member discount.
CLICK HERE
DS2500
Although we always recommend using a dedicated race pad for the track, the DS2500 is one of the best hybrid street/track pads on the market. It features the moderately high bite and solid fade resistance of a track pad, with the relatively low dust and noise levels of a street pad. When used as a street pad, it can produce some squeal on certain vehicle platforms. During aggressive driving the DS2500 is known for its flat torque curve, which means as temperatures go up, the response through the brake pedal remains consistent. If you drive aggressively on the street, do some canyon runs, autoX, and maybe some light track duty on street tires, the DS2500 is tough to beat.
When used on high HP, heavier cars (2,800 lbs+) on the track with race tires, pad wear rates tend to be higher than on Ferodo Racing's other pad compounds. Under those conditions, Essex would recommend the Ferodo DS1.11 or DSUNO.
DS1.11
The DS1.11 is one of Ferodo Racing's latest endurance race pad offerings. It has slightly less bite at high temps. vs their older DS3000, but doesn't decompose nearly as quickly under extended heavy use on the track. The DS1.11 is known for its extremely flat torque curve, which means that as temperatures go up, the response through the brake pedal remains consistent. The DS1.11 can be thrashed all day without having it burn up or fade, it's easy on discs, and doesn't have many of the judder or vibration issues that competing products have. If you want an extremely solid, all around race pad that will perform well and last a long time, the DS1.11 is the perfect choice.
DSUNO
Ferodo Racing has made great strides in pad development over the past few years, and DSUNO is their latest offering. For our customers who enjoy the performance of the DS1.11, but just want a little more bite, we recommend the DSUNO. It doesn't wear quite as long as the DS1.11, but it does offer a higher overall mu once it reaches track temperatures.
Zitrosounds
Madison, AL
Harold
Will the Big Brake kit rotors be compatible with the stock Brembo calipers?
"Big brake kit rotors" as in bigger than whats on the 350 already!?! If you are referring to the kit shown above that is actually a lighter smaller diameter kit.
Hack
Minneapolis
Mustang, Camaro
Anyone using these pads - please post your feedback on them!
Status
