Steeda's Camber Plates - Review & Install Courtesy of LMR
tj@steeda
Timothy
Hello All:
Another great install & review video from our friends at LMR ... a must for additional camber adjustment!
Ideal for any lowered street or track Mustang
Reduce excessive uneven tire wear which can result from lowering your car
Most adjustment range on the market: adjust camber angle from -0.3 degrees to -2.8 degrees
Highest quality, stainless steel, Teflon-lined bearings included
Nickel-plated bearing housing, Tig-welded and CNC machined to exact tolerances
Grade 10.9 hardware and nylock nuts included
Increased front grip, turn-in response and cornering performance
Reduced understeer
Increase overall cornering capability by .11 G's
No increase in NVH
Specifically designed for the S550 chassis and front suspension system
No permanent modifications required
Steeda American-made quality, backed by a lifetime warranty
Compatible with KW Suspension V3 Coliover Kits and Performance Pack shocks
[ame]
