wildcatgoal
@sirboom_photography
My understanding is that the GT4 uses the stock vertical link but with a stiffer durometer bushing, which Ford Racing has done a lot in the past. This higher durometer bushing inside of it, worth nothing, basically looks the same as stock - it is the same size and consequently provides the same potential range of articulation and motion control as does the stock bushings within the vertical link. You either create a bushing with the same/similar shape, just higher durometer, or a larger "flat" non-rubber bushing that can have some give in it and therefore ends up sized looking large, extending beyond the metal structure of the lower control arm and knuckle mounting points (so it doesn't prematurely crack like some previous poly vertical links I had a long time ago doing so after one single track day), or you go with an appropriately sized spherical bearing, which I've had and clearly moved on from as my car handled better especially under hard braking with something that has a bit of give to it (but everyone likes a different animal).The Mustang GT4 is and does. Stock integral link. Just ask the guys at Kohr.
Maybe you and Steeda should inform Ford of the benefits of using your integral links, since they can build an entire new billet LCA for their quarter-million dollar factory race car, but apparently don't understand or know the benefits of an aftermarket integral link. Lol.
