- Oct 17, 2014
- United States
- Website
- www.steeda.com
- David
- Bolt-on, slammed S197
You asked and we listened! The wait is finally over, Steeda's S550 camber plates (#555-8139) for your 2015-2016 GT, EcoBoost and V6 Mustang are in stock and ready to ship!
At Steeda we're looking to continually push the boundaries of the new 2015-2016 Mustang's suspension. From the factory, the OE components are designed without any camber adjustment for alignment purposes. The factory strut mounts also utilize a bushing style mount resulting in excessive bending stress on your dampers, steering system bind, and may even cause pre-mature failure.
Our Steeda S550 camber plates are made right here in the USA and are great for both street and track use. Our camber plates come into play especially when lowering your vehicle. With the addition of our new adjustable strut mounts on your lowered S550 you will be able to correct excessive negative camber and increase your front steering response. If you lowered your daily driven S550 Mustang, running the correct camber will eliminate uneven tire wear.
With the addition of these camber plates you will be able to dial in precise front suspension camber for each front toe adjustments resulting in a more balanced and predictable vehicle on the street or track. You will notice improved overall handling capabilities, elimination of understeer and increase in your Mustang's turn-in response. In testing, we have seen maximum lateral acceleration increase by .11 G's post-installation of our Steeda camber plates; maximum lateral acceleration may vary depending on other variables such as tires or outside weather factors. If you're in the market for springs or anything else that requires an alignment, these camber plates are a great addition.
Key Benefits:
- Ideal for any lowered street or track Mustang
- Reduce excessive uneven tire wear which can result from lowering your car
- Most adjustment range on the market
- Adjust camber angle from -0.3 degrees to -2.8 degrees
- Highest quality, stainless steel, Teflon-lined bearings included
- Nickel-plated bearing housing
- Tig-welded
- Grade 10.9 hardware and nylock nuts included
- CNC machined to exact tolerances
- Increased front grip, turn-in response and cornering performance
- Reduced understeer
- Increase overall cornering capability by .11 G's
- No increase in NVH
- Specifically designed for the S550 chassis and front suspension system
- No permanent modifications required
- Steeda American-made quality, backed by a lifetime warranty
Many of you have been asking for Steeda to develop S550 camber plates, and we're happy to announce these are $269.95, in stock and ready to ship!
Product Link: Steeda S550 Mustang Camber Plates (15-16 All)
Key Benefits:
- Tig-welded
