2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com 15 - Steeda - 2
Homepage Wiki MOTM Register Search Today's Posts Mark Forums Read Ford Bronco Forum Calendar Garage
Go Back   2015+ S550 Mustang Forum (GT, GT350, GT500, Mach 1, Ecoboost) - Mustang6G.com > Sponsor Forums > Livernois Motorsports
User Tag List
Reply
Thread Tools Search this Thread Display Modes
Old 04-27-2017, 12:37 PM   #1
Livernois Motorsports's Avatar
Drives: 2015 EcoBoost Mustang
Thanked: 695 Times in 483 Posts
Garage
iTrader Score: 0 reviews
Livernois Motorsports 5.2L Voodoo Head Studs AVAILABLE NOW!
Livernois Motorpsorts Powerstorm 5.2L Voodoo Head Studs
LPP701122
$339.99
Name:  5.2 voodoo head studs.jpg
For the best Ford 5.2L Voodoo head studs in the industry, look no further than Livernois Motorsports.
Featured below are just some of the important differences between the 5.2L production head bolt, a competitor’s offering, and our new Powerstorm 5.2L head stud kit.
Stock Bolts
Starting with the comparison to production bolts. Immediately apparent is the first substantial improvement; switching from a bolt to a stud. While the production bolt is satisfactory in a stock power application, higher power outputs necessitate something with more clamping force. In this area, studs are superior to bolts because they allow the stud to be stretched evenly without a twisting force being applied to the shank, as happens with a bolt.
When it comes to the material, there is no comparison. This Powerstorm head stud kit utilizes 8740 Chrome Moly that is significantly stronger than stock torque-to-yield fastener. This higher strength material allows for a higher tensile strength fastener, which means more clamping load can be applied. This allows for the two components have increased clamping load, keeping the head in place under a higher power. By preventing shifting of the cylinder head, you will greatly reduce your chances of gasket or component failure.
Name:  washers highlited.jpg
The Competitor
When it comes to deciding which aftermarket 5.2L head stud you want, it's important to remember that just because a product is listed as compatible, does not mean it's the optimal choice. While it may be difficult to decipher which is the best option upon first glance, when you dig further into the details it becomes abundantly apparent.
Firstly, and in our opinion, a major issue in the competitor's offering, is that it is not a stud designed for the unique characteristics of the 5.2 Voodoo block, that they are merely an off the shelf part. While this in and of itself is does not make it a bad stud by any means, it’s critical failure is that it’s threads are of inadequate length to fully and properly engage in the block. This lack of thread engagement creates a situation in which the upper threads are pulled upon disproportionately, and with the much higher load being exerted from the higher strength material we have witnessed it resulting in block failures. These off the shelf studs sacrifice nearly 30% total thread engagement compared to our custom designed Powerstorm Head Studs.
The Livernois Motorsports Powerstorm head stud kit is custom designed to exactly match the Ford 5.2 Voodoo block and offer improved stud engagement. To better ensure properly distributed clamp loads, we also utilize a washer that mimics the size of the stock washer, where as the competitor's offering actually uses a noticeably smaller diameter piece.
Name:  Screen Shot 2017-04-19 at 4.17.04 PM.png
Additional Upgrades
Powerstrom Billet Main Caps – LPP701144
Powerstorm Billet Main Caps + Powerstorm Studs – LPP701147
Powerstorm Sleeved 5.2L Block – LPP750122
For those needing to add even more strength of your block, the Powerstorm Billet Main Caps are a great addition. The 5 piece billet steel cross bolted main cap set is strong enough to handle over 1,000hp. These caps are made of 1044 billet steel to make them the strongest on the market. With these upgraded Powerstorm billet steel main caps, you can extend the strength and reliability of your block far beyond that of a production Ford block.
Also available from Livernois Motorsports, OE 5.0 and 5.2 blocks with our iron sleeves and billet main caps installed for the ultimate performance block available. Contact Livernois Motorsports for more information.
Name:  billet main caps.jpg
(313) 561-5500
info@livernoismotosports.com
www.livernoismotorsports.com
__________________
Livernois Motorsports is offline   Reply With Quote
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
ARP Head Studs for 2016-2017 5.2 Shelby GT350 @ mmr Mod Mustang Racing 5.2L V8 Voodoo Engine Mods & Bolt-Ons 9 04-11-2018 11:34 AM
WTB ASAP ARP Head Studs TheHydro Want-To-Buy & Trade Requests 0 03-09-2017 07:56 PM
ARP 2000 Head Studs for 2015-2016 2.3 Ecoboost Mustang Mod Mustang Racing I4 Engine Internals 4 05-19-2016 04:13 PM
You will Love the Voodoo that we do at Livernois Motorsports Livernois Motorsports Livernois Motorsports 0 04-21-2016 12:30 PM
ARP GT350 Head Studs Part No. 256-4702 ITLRUN 5.2L V8 Voodoo Engine Mods & Bolt-Ons 3 01-26-2016 06:02 PM
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging v3.2.4 (Lite) - vBulletin Mods & Addons Copyright © 2018 DragonByte Technologies Ltd. Runs best on HiVelocity Hosting.Navbar with Avatar by Motorradforum
Garage vBulletin Plugins by Drive Thru Online, Inc.
