65Terdlingua
- Apr 29, 2015
- Kansas City
- 1965 Mustang
2D bar code on the rod bearing? Is that a normal thing to see on these?
That's pretty common.Direct injection pump runs off camshaft?? Even more strain on the crank sprocket???
Pretty soon there will be another RECALL,crank sprocket will end up just like the half shafts,bang and in pieces.:doh:Direct injection pump runs off camshaft?? Even more strain on the crank sprocket???
The fact that upgraded opg and timing gears aren't offered in a performance pack is beyond me. That's just extra profits left on the table for the aftermarket to capitalize on. The rods are actually stronger than those of the second gen.Gears need to be fixed.
Rods look weak for boosted applications.
You couldn't be more wrong. The spray in lines are actually significantly stronger than sleeves. They also allow more room for cooling around the cylinders.I wonder how the, for lack of a better term, "spray-in-liners" on the cylinders will hold up on boosted applications?
My guess is, not very well. Will this be the Achilles heel of the 2018 Coyote engine for boost loving peeps? There is no way I would run this engine with any boosted application without sending the block out to have it sleeved.
That block is only as strong as the cylinder liners, and quite frankly, those scare the schiznit outta me. Time will tell.
That's what MMR is for.The fact that upgraded opg and timing gears aren't offered in a performance pack is beyond me. That's just extra profits left on the table for the aftermarket to capitalize on. The rods are actually stronger than those of the second gen.
You do know that the Plasma Transfer Wire Arc (PTWA) process was used in the supercharged '11-'14 GT500 cars, right? ...and that Nissan pays a license to use it in the GTR engine as well?I wonder how the, for lack of a better term, "spray-in-liners" on the cylinders will hold up on boosted applications?
Where did you get that info from?The rods are actually stronger than those of the second gen.
I watched a video recently in which a senior FORD engineer talked about the "spray in liners" and of how they were new to the third gen Coyote motors. Also, the pics showing the bores of the gen 3 above clearly indicate the liners, if we can even call them that, are paper thin at best, and much, much thinner than the gen 2 Coyote engines.If I recall it's the same liners used in the 2013-2014 GT500 and 2015+ GT350. So considering the fact it's been used in a boosted application from the same manufacturer it should be fine for boosted applications.
