BoosTang23T
So basically you don't recommend me going in cleaning the IAT? Do I try cleaning the MAP or just leave it as? For the K&N I have not re-oiled it... It still need more miles on it before it is required.Some of the You Tube videos on this subject are hilarious. Remember, ANYONE can post a video.... The guy with the Ford Truck that says he says 3 MAP sensors. :headbonk: Theirs is very similar to our Mustang ecoboost. It's actually an IAT (Intake Air Temperature) sensor he was looking at that he thought was a MAF (Mass Air Flow) sensor and was calling a MAP sensor. The sensor on the outlet of the intercooler is functionally like a MAP sensor, it's the Turbocharger Boost Pressure Sensor. The actual MAP sensor is on the manifold. So all similar. Plus where the MAP sensor is located, you should absolutely expect oil vapors in the air and will be on the sensor, this doesn't effect its operation or they wouldn't use it.
Cleaning a MAF sensor or better yet replacing it can make a big difference and is mostly a problem when people use an oiled air filter like you have and they over oil it. That oil comes off the filter and coats that thin sensitive wire on the MAF making it so it can't properly determine the volume of air passing though. It actually senses less air because of the oil so it tells the computer to provide less fuel making your engine run lean. If that was the case, you could see this on your cluster the A/F would be too lean based on the fuel you're running. But I digress as like I said, we don't even have a MAF sensor.
MAPs aren't the same, they aren't measuring a stream of air and trying to determine the volume based on temperature and velocity using the known opening, they are just measuring the pressure against a diaphragm. People that clean the MAP are thinking it's like a MAF and just trying to do the same thing they did with the MAF because they don't know the difference. They think they are both measuring airflow so must be the same. Look for a can of MAP sensor cleaner. ;) Notice they are using MAF sensor cleaner in the videos.
