*Team Beefcake Gen 3 Whipple Exclusive! - Pics, Kits, Upgrade Package info and more!
beefcake
Bethel
2018 Ford Mustang
Just wanted to share some info on new Gen 3 Whipple and the upgrade packages, and our custom packages.
As i'm sure alot have heard, the Gen 3 Whipple will be a nice upgrade!
For those that haven't, this is what you get.
- Adds up to 30-150 hp/tq at the same boost level
- 10-80*F cooler temps
- New Whipple Crusher SC Housing for increased volumetric efficiency
- Simple bolt-on upgrade to existing Gen 1 and Gen 2 2.9L/W175AXFF superchargers
Whipple Superchargers, known for years of innovation, have now developed the new Gen 3 Whipple 2.9L supercharger that features both updated rotor design and rotor housing to unleash even more power from your engine. The Gen 3 works with nearly all 2.9L Gen 1 and 2 applications and is a simple upper half swap. No tuning required, just more power by increased supercharger efficiency.
Gen 3 features all new 3/5 rotors that feature a new updated rotor profile and new advanced manufacturing methods, allowing more accurate and tighter tolerances along with increased efficiency. Each Gen 3 rotor also features a later generation robotically sprayed conformal rotor coating, allowing the rotor clearance to conform to the operating conditions and application. The Gen 3 also features upgraded double lip PTFE rotor seals for higher RPM, higher temp and higher pressure ratios.
The Gen 3 also features a new rotor housing with the new angled support ribs for a more aggressive appearance, along with revised port shape for increased rotor filling and decreased turbulence, resulting in increased overall supercharger efficiency. What does all this mean? More power, more power, more power while maintaining the same boost levels.
During extensive testing on multiple applications, both Whipple and 3rd party testing found gains from 30RWHP up to 150RWHP depending on blower speed and engine specifications. Standard pump gas applications can easily make another 30RWHP with no other changes. Because boost maintains, tuning is not required. Just bolt on and unleash the power of your stock application.
Have a nice graph comparison attached below!
Also, in addition, those that have an existing kit, can simply upgrade to the new Gen 3 Whipple by adding this package.
For S197 & S550 Cars - http://www.teambeefcakeracing.com/whipple-wsc-175ffb-g3.html
For those with an S550 that are picking up a used Gen 2 Blower, you have 3 options. And, under all 3 options, you still have the ability to add things like inter cooler or fan upgrades, tune delete, etc..
You can turn it into a stage 1 complete kit with this package
http://www.teambeefcakeracing.com/whipple-wk-2620s1-parts.html
You can turn it into a stage 2 complete kit with this package
http://www.teambeefcakeracing.com/whipple-wk-2620s2-parts.html
If you want to turn it into a tuner kit and add your own fuel or tuning, you do that here
http://www.teambeefcakeracing.com/whipple-wk-2620t-parts.html
And of course, if you just want to jump into one of our custom beefcake specials from scratch!
http://www.teambeefcakeracing.com/bfspcwhipple-wk-2620tb-gen3.html
And, in for some great pics!
beefcake
beefcake
Bethel
2018 Ford Mustang
if anyone thats selling a blower to an 11-14 guy
we now have the part #s on the site for their setups as well
Whipple Gen 3 Parts Box Stage 1 (11-14 Mustang) WK-2610STG1-PARTS
Whipple Gen 3 Parts Box Stage 2 (11-14 Mustang) WK-2610STG2-PARTS
Whipple Gen 3 Parts Box Stage 3 (11-14 Mustang) WK-2610STG3-PARTS
Whipple Gen 3 Parts Box Tuner Kit (11-14 Mustang) WK-2610T-PARTS
BDMACH1
Ravenna, Ohio
Bob
2016 Mustang GT/CS
Got the email yesterday Terry, is the new 150mm throttlebody on the website too? I want to do the Gen3, I think there is a machining charge as well. Can you get us pricing on what it is to machine the blower and how much the new throttlebody is?!?
Bob
beefcake
beefcake
Bethel
2018 Ford Mustang
Bob
the tb is $650 retail and the machining is $200
Performance nut
TX
2018 Mustang GT A10
What were the mods to get the results in the dyno?
Do you need to buy a tune or does the kit come with a Whipple tuner?
beefcake
beefcake
Bethel
2018 Ford Mustang
if you buy a complete kit or a lower end package, you get whipples tune.
tuner kits you have to have custom tuning done
beefcake
beefcake
Bethel
2018 Ford Mustang
hoping to have our first one to test soon
