I'm at 12.5ish on the 3.5 so with 20% that's 4.2 which they do have a 4.2" pulley but I did forget I was running Octanium :lol: so yeah I probably won't be able to do that.With a 10 rib gen 3 and 20 od I hit 17.3lbs.
I was told every 1/8” reduces boost by 1lb.
A 4” will ballpark 15 lbs or so, I I would expect that still to be too much for pump 93.
The 4.25" just barely fits. You can run 15psi on 93 on a built motor, with proper timing but using boostane would really help.With a 10 rib gen 3 and 20 od I hit 17.3lbs.
