Interior noise/rattle/buzz from headlamp switch
Budnr22
Northern VA
2016 GT350 - Oxford - Tech Pack
SSM 45189 - 2015 Mustang Headlamp Switch Bezel Buzz Or Tick Noise Built On Or Before 4/30/2015
Some 2015 Mustang vehicles may exhibit a buzz or tick noise from the headlamp switch bezel while driving. To address this concern add a 10mm (3/8") x 60mm (2 3/8") piece flocking tape (164-4903) from the Rotunda Squeak and Rattle Kit (164-4900) to the headlamp switch bezel right side edge. Remove the headlamp switch bezel and add the tape to the right side edge folding the tape over the edge at the center of the edge. Refer to Workshop Manual (WSM), section 417-01 Headlamp Switch Removal and Installation for procedure on bezel removal and installation. Use applicable service labor operations in Section 11 of SLTS manual
Budnr22
Northern VA
Me too. Mine sees a to be getting worse over time
ib2loud
Oklahoma
Brad
2015 Ecoboost
Had the TSB done today. They had to order a part in yesterday. The switch rattle appears to be gone but I still have a buzz/rattle from the A pillar and also sometimes from the center of the dash and the rear passenger plastic as well.
Ender
Phoenix, AZ
2016 B5 Blue Challenger Scat Pack
Do any of you have the TSB #? I can't seem to find any information on it.
ViolentDreams
Southern California
'99 Silverado - '15 Ecoboost
Thats because it's an SSM not a TSB, all the info is in the first post.
Ender
Phoenix, AZ
Gotcha. The guy above had said TSB so I just assumed maybe there was one out for it.
Ap8823
Las Vegas
Anthony
2015 EcoBoost Premium
So if I brought my car into the dealership and said there is an ssm on my car they would know what I'm talking wbout?
Turbo Ghost
Metro Detroit
Jeff
Ecoboost PP
If you tell them you have an intermittent rattle/buzz from the headlight switch, and there is a related SSM, they should get you taken care of with no hassle.
ib2loud
Oklahoma
Brad
2015 Ecoboost
I just showed the advisor this thread and they looked it up.
smdandb2
ManBearPig
Uranus
2017 Toyota Corolla SE
HAHA, that is funny.
That is exactly what I did to my switch a few months ago.
gsxr1300
MA
Jason
2015 Mustang GT PP
Does it just pull off? Id rather do it myself.
Ultimateone
Yes is that's guy /\
Boston, MA
F32 435i Xdrive
ViolentDreams
Southern California
Remove the lower dash trim panel (held on with clips), then one screw holds the headlamp switch on.
ultimate warrior
Lakeland, FL
2016 Ecoboost
I went through and did this myself.
I broke a white plastic clip on the bottom panel removing it (ones that can be replaced).
Pulled the low left panel off and there is a single screw holding the top bezel on.
After the screw is removed the healdight trim bezel panel pops straight out (is held by 4 clips, 2 plastic, 2 metal on plastic.
After that you can remove the headlight switch controller from the assembly by pressing the plastic tabs down and pushing the assembly outward.
I lined the inner ring around the controller with felt and pressed it back in. It locked in much, much more firmly this time then OEM. I also added some strips of felt around edges of the trim piece.
Will report back.
