Bluemustang
Thanks BmacIL. I will just have to do some experimenting, as I was going to do anyways. I would think though, the rear spring rate so high, and the rear sway bar rate being proportionally higher than the front bar rate in comparison to the stock bars, that my feeling of oversteer is likely correct.It is additive but you have to keep in mind the motion ratio. The front is essentially the same as the front strut. The rear is pretty much at the shock mount, so it has a larger motion ratio (approximately 0.75) than the spring. Then you have to apply that torsional stiffness of the bar with those motion ratios to the wheel rate. There's no true optimal rate, as it depends on what the balance of the car you want. There are optimal ranges for them, but not specific points. I'd need more data about the body/chassis of the car to answer that question.
I found an article on MotoIQ re: suspension tuning and it mentions several ways to influence oversteer/understeer balance by way of either spring rate, sway bar rate, struts/shocks damping and also, believe it or not, tire pressure. And of course, a combination of all of the above. It goes on to explain that increasing the rear tire pressure can help to reduce the oversteer so I'm going to try that as well.
http://www.motoiq.com/MagazineArtic...-and-Handling-Part-3-Balance-the-chassis.aspx
