BMR Tech Tip: Clock those bushings after lowering your S550!
Status
Not open for further replies.
Southview
Viera, FL
Herby
2015 GT Premium Convertible
Open the trunk. Sit on edge of trunk opening and bounce up and down.
CoolRod
West Coast Florida
If I drop the rear cradle (I have access to a lift) to install my BMR springs, do I still need to re-clock all of the bushings?
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
yes because its done with the full weight on the suspension, otherwise it will not work...
MtnBiker
San Antonio, TX
2015 Mustang GT PP
Yes because you are changing your ride height. That changes the suspension geometry. Need an alignment too.
CEHollier
Prairieville, La.
Charles
2015 GT Premium Magnetic
I'm fixing to install PP dampers and BMR minimal lowering springs. I read this post from start to finish and did not see this question answered. For simplicity I'm going to have the guys doing the alignment clock the bushings. Some members mentioned driving 50 miles or so to allow the springs to settle. Does it matter driving the 50 miles before or after clocking the bushing and doing the alignment?
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Do it whenever is feasible before the alignment. If you have the equipment, do it immediately after installation. Otherwise they should be able to do it on the alignment rack. It's an odd request but a good shop will do it.
HoosierDaddy
Randy
2016 GT Premium PP
I don't KNOW but since factory springs also settle and I have never heard anyone say they either needed or did re-clock after the factory springs settled, it would seem okay to do it at time of install. But if the cost is the same to wait, might as well get that final fraction of benefit.
CEHollier
Prairieville, La.
Charles
I'm installing them myself on jack stands so the clocking won't get done until the alignment. Guess I will put 50 or so miles on the springs after install then do the alignment. Thanks.
turbojay
Illinois
20 GT A10
Great info here. I’m happy I stumbled on to this thread as I plan on doing springs and bushing this weekend. Thank you!
jabrax
Montgomery County PA
Jeff
2015 ruby red PP GT
Hey Hoosier, this has nothing to do with springs settling, and everything to do with the car being lowered from factory settings that can bind up the bushings. It is not uncommon for someone to say the car is seems uneven and lopsided after lowering. Also, the chance of premature wear is introduced to the bushings.
Plenty of threads where people complain of the cars appearance after lowering. It can usually be traced to needing this done after lowering
JKL1031
Jxn, Ms
15 GT PP Premium
A good plant doesnt torque those type of bushings until the car is on the ground, or they have something that presses the rear arms in ground position when the rear cradle is being sub assembled. ;-)
Monica_Stang
Long Island
Mustang Ecoboost Performance pack
Wish I would have known this before I lowered my car. I just discovered reclocking a few days ago after having squeaks coming from the front when going slow in parking lots...I’ve been lowered for a year and a half now.
Luckily I’m going in for an alignment this week because my steering feels off. Maybe it’s my bushings rather than my alignment though.
Hopefully reclocking would solve this and my bushings aren’t too far gone. I’ve already tried lithium grease and still have the squeaks
MtnBiker
San Antonio, TX
2015 Mustang GT PP
This suspension is really particular about proper torque on those fasteners or you'll get squeeks.
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
I did progressive springs two months ago and no squeaks so far, work done at dealership and was a 4 hr. job. The job is serious and requires skill, 3 hr. per axle for billing purpose so the Service Mgr. tells me. Now I need Bilstein shocks & struts to pair with the drop.
BmacIL
Enginerd
Naperville, IL
:lol::lol:
To do springs it takes maybe 1.5-2 hrs per axle TOPS on jackstands by yourself. On a lift maybe 1 hr. I'd go somewhere else. If you're just adding dampers, that's 1.5 per axle for the front and about half an hour per rear if taking your sweet time. Sounds like someone is padding the time.
Status
