speedaholic
- Aug 11, 2015
- Montreal, Quebec
- 2015 Black base GT
OP, if the rear harshness your experiencing is bounce, you might want to look in to the Steeda rear billet shock mounts before changing springs. They have spherical bearings that prevent binding of the damper's shaft, which can explain the bounciness felt with the OEM mounts.
I've had for 3 months now the ProAction fixed combined with Sportlines (which have the most aggressive spring rates for progressives), rear billet shock mounts and BMR CB005 cradle lockout. This combo is flawless for an "install it and forget it" setup; albeit stiffer, there's no bounciness at all, doesn't bottom out, is very stable at high speeds and I can power out of corners like never before.
