papinist
The Italian Pony
- Nov 30, 2014
- Tuscany, Italy
- Stefano
- Mustang EcoBoost MT Race Red EURO - NO MORE
UPDATE 29/10/2015: Upon checking directly inside the front fender (thanks to Lsstefan) we find out that the instruction manual is wrong: we don't have PY21W bulb (BA15S socket) but WY21W (T20\7740 socket), so some info on the first post are outdated.
Hi guys,
I have this idea since the day I order my Mustang: how could we have the front turning lights to turn on together with the parking lights (preferably white), and then blinking when turning?
For our american friends, it's too easy: they already had this, and to have parking lights white and turning lights amber they could buy Diode Dynamichs switchback, or simply go to ebay and pick one of the many offers.
We, as always, have some more issues, first of all our turning lights are not intended to stay on as parking lights, and then we have completely different socket for the bulbs.
In the past days I searched the net and collected some info.
First of all, what is a switchback lamp? It's like two-bulb-in-one lamp. It has white leds for parking lights that goes off when turning, when it blinks amber
(actually, parking lights could also be amber)
There are two switchback type:
- TYPE 1: when blinking, it's amber-white-amber-white
- TYPE 2: when blinking, it's amber-off-amber-off
US Mustang turning light specs
Front park and Direction indicators 7444NA (amber)
From another forum:
I was just thinking: ok, we can use 7443 switchback, with some sort of adapter.. but our are really different!
EU
Front direction indicator. PY21W (BA15S) (similar\identical to 1156 socket)
Our turning light uses a 'Y'ellow filament bulb and the connector isn't compatible at all with 7443.
After thinking at how much adapters\connectors I should buy and solder, I just did a simple search on ebay and found that the solution already exists!!
http://www.ebay.it/itm/271603385411...49&var=570436738525&ssPageName=STRK:MEBIDX:IT
It's perfect! It connects to the existing BA15S socket, the lamp has a rubber that should go in the existing hole and has the load resistor.
The amber turning light function is assured, and for the white parking light we simply need to connect the spare wire to the + wire of the nearby parking light.
I send a message to the vendor to be sure these are type 2 switchbacks (Edit: just replied, yes! Type 2 switchbacks!)
I'm searching for a W5W socket extender so I avoid modifying the other harness to steal power
Other auctions:
http://www.ebay.it/itm/281762614277?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.it/itm/161725818796?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.it/itm/161762291425?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.it/itm/331605225601?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
http://www.ebay.it/itm/311466924819?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
These are a bit different, don't know if that spare wire could exit correctly from the socket:
http://www.ebay.it/itm/151533076677?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
This could be a very simple solution :clap2: :cheers:
I'll try to order one of these set and try!
Next, will be the tribar led drl.. addle:
Hi guys,
From another forum:
So 7444NA is the one used in US Mustang (amber parking and amber turning) and 7443 led switchbacks are the ones that US guys use to obtain switchback functionality with white parking and amber turning.They are confusing. 7443 and 7444 are both clear/white automobile light bulbs and 7443NA and 7444NA are both Natural Amber/yellow automobile light bulbs. All four bulbs are dual filament which means they are two light bulbs in one. 7443/NA is rated at 12 volts 21/5 watts and 7444/NA is rated at 13.5 volts 28/8 watts which means 7444/NA is supposed to be a little brighter. My Mazda CX-5 owner's manual listed rear turn signal as WY21W/7443NA which is definitely wrong as only single filament bulb is required for the application and the equivalent number should be 7440NA which is rated at 12 volts 21 watts. Although if you plug in 7443NA or 7444NA dual filament bulb it still works due to the design of the contacts within bulb socket. It is just that the lower wattage filament will never be used. If you plug in 7440/NA into a 7443/NA or 7444/NA bulb socket it also works but you lose lower wattage application as 7440/NA is a single filament bulb. Equivalent LED light bulbs will have different results depending on car manufacture wiring by the way.
EU
Other auctions:
