- Dec 18, 2014
- Atlanta, GA
- 2015 6spd GT
2015 Ford Mustang 50th Anniversary STO-N-SHO Removable License Bracket
Big Mike's has done it once again! Come up with the perfect solution to a very common problem. How the heck can I mount a license plate on the front of my 2015 Ford Mustang? Checkout these brackets. Available for standard 2015 Mustang and 2015 Anniversary Mustang....
Standard Mustang Here (V6, GT, etc, non Anniversary model): http://www.southerncarparts.com/201...o-removable-license-plate-bracket-p-6525.html
Anniversary Mustang Here: http://www.southerncarparts.com/201...versary-sto-sho-removable-license-p-6505.html
Big Mike’s Performance Parts’ STO N SHO™ is an aftermarket detachable front license plate mounting system that is designed for those cars whose appearance would be ruined by use of the factory mounting location. Stay in compliance with state law by simply STOing your front license plate when you want to SHO the beauty of your car.
Big Mike’s Performance Parts’ STO N SHO™ is a two-piece detachable mounting system consisting of a front license plate holder and a base mounting plate.
Removal and installation of the front license plate is easy
Requires only the pull of a spring loaded pull pin Remaining base plate is virtually undetectable The STO N SHOTM aftermarket detachable front license plate bracket mounting system is manufactured in the USA using quality materials and parts. The front and base plates are precision laser cut and hand burnished. Each tube and rod is machine cut and hand cleaned. Each STO N SHOTM aftermarket detachable front license plate bracket mounting system is expertly hand welded and drilled. After it’s assembled the base plate welds are ground smooth. The bracket is then anodized black. The final step in the process is to install the pull pin and test the product. While the bracket may look simple in appearance, a lot of time and work goes into making each STO N SHOTM aftermarket detachable front license plate bracket mounting system to ensure you receive a quality product.
Constructed of 5052 and 6061 aluminum Welded and anodized black Built to last and comes with a limited life time warranty Big Mike’s Performance Parts” STO N SHO™ requires small holes to be drilled on the underside of your vehicle. These holes are not visible and in no way detract from the look of your car.
Requires 2 holes All parts required for installation included, however, tools are required.
