Lethal Performance talks about Mcleod Clutches (Tech Tips Video)
Chris@Lethal
Wellington Florida
Ford
On an almost daily basis we are asked "Which McLeod clutch kit should I get?!" Guys with GT500s, supercharged Mustang GTs & many others sometimes are torn on which setup is the right one for their application.
Jared, our head honcho, wanted to take some time and go over the McLeod RST and RXT clutch kits & which part #s you will need for YOUR setup, including the corresponding slave cylinders and even guys with a TR6060 swap.
[ame]
Did you get all that? We understand the information can be a bit overwhelming for some but we just want to make sure you are getting the RIGHT clutch & accessories for your setup. Here's some notes:
McLeod RST:
- Organic Compound Discs
- Bolt-on or Forced Induction cars ~700rwhp
- Street car setups only; RST cannot withstand the heat of track use
McLeod RXT:
- Ceramic Compound Discs
- Great for track use
McLeod RXT1200 Heavy Duty:
- Same as RXT but pressure plate has a higher clamping force
Let's move on to specific applications:
2007-2009 Shelby GT500
RST: 6908-07
RXT: 6918-07
RXT HD: 6918-07HD
These come with a lightened steel flywheel & use the factory, longer style slave cylinder.
We HIGHLY recommend purchasing these kits & not using your factory flywheel as the OEM flywheel has a 7” opening for the hub where the McLeod disc only has a 6 1/8” hub. This causes the friction surface to sit inside of where it meets the flywheel, giving you less contact. This in turn leads to faster wear & improper clutch hold.
NOTE: If your car has been into Ford for the clutch TSB (10-3-8 or 8-16-4), then you have a 2010+ GT500 clutch & short slave setup in the car and will need the 6975-07M or 6975-07HD setups instead.
2010-2014 Shelby GT500
RST: 6975-07
RXT:  6975-07M
RXT HD: 6975-07HD
These work with both your factory flywheel and shorter style slave cylinder.
These will all work with your factory flywheel. You do NOT need to purchase a flywheel, no matter that the condition of your stock flywheel is.  The 6975-07 series comes built with it's OWN friction surface that is between the discs and your OEM flywheel. We do offer a stock replacement from McLeod (SKU: 473458) but again, it is NOT needed.
The 6975-07 clutch kits are sprung hub, dampening driveline vibrations & offering smoother engagement than the solid hub setups.
2005-2010 Mustang GT
10 spline RST: 6912-03
10 spline RXT: 6932-03
10 spline RXT HD: 6932-03HD
Will work with factory flywheel, but a replacement flywheel is recommended (Lightened Steel Flywheel, SKU: 463456 for 6-bolt, 463458 for 8-bolt).
NOTE: For 26 spline, change '03' in SKU to '07'.
2011-2017 Mustang GT
The options for this car are a bit more expansive.
Solid hub RST: 6912-25
Solid hub RXT: 6932-25
Solid hub RXT HD: 6932-25HD
These will need either a lightened steel flywheel (SKU: 463458) or an aluminum flywheel (SKU: 563408).
Sprung hub RST with Steel flywheel: 11176975
Sprung hub RXT with Steel flywheel: 11176975M
Sprung hub RST with Aluminum flywheel: 11176975A
Sprung hub RXT with Aluminum flywheel: 11176975MA
We know there are rumors & urban legends that the RXT will destroy your MT82 right away, however we've run an RXT in ALL of our cars, including multiple MT82s, and we have not had an issue. These cars were NOT babied, either.
2011-2017 Mustang with a TR6060 Swap
If you swap a TR6060 into your car, we will basically treat it as a 2010-2014 Shelby GT500. Here's what you will need from McLeod:
RST: 6975-07
RXT:  6975-07M
RXT HD: 6975-07HD
You will also need to purchase a short slave cylinder (SKU: DR3Z-7A508-A)
_____________________________________________________
All this info is also available at: https://www.lethalperformance.com/info/mcleod-racing-clutch-kits-101
We hope this helps you out!
Give us a shout with any questions.
877-2-LETHAL (561-753-8105)
Email: [email protected]
Anthony 05 GT
Northern Harford County Maryland
2005 Mustang GT, 2015 Mustang GT Premium
Jared is right on the money with his recommendations here. I'm a true McLeod fan repeatedly. I met Jared back in '06 at the NMRA event in Bradenton Fl. He was a heck of a nice guy.
whatsup62
Jupiter
Awesome info!! Thanks a bunch...I will not run anything other than McLeod in this car period!
racingmason
NC
2017 GT Premium
Good Info. I beat the snot out of my RXT MT82 and no issues. Hard launches on slicks with factory halfshafts and they haven't broke yet either.
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
Thanks for posting this video, still trying to choose between the RST (sprung hub) or RXT (sprung hub) for my T56 swap. Car will be around 650 rwhp, I don't see it going over 800 rwhp unless I spray it which is unlikely. Street car, built for road trips, backroading, occasional HPDE.
Looks like I will need of of these kits:
RST - https://www.lethalperformance.com/m...st-clutch-package-for-use-with-magnum-xl.html
RXT - https://www.lethalperformance.com/m...xt-clutch-package-for-use-with-magnum-xl.html
Gonna have to make the call on what friction material soon. Any chance y'all are having a July 4th sale?
Wolverine
Huntsville, Alabama
'17 Oxford White Premium GTPP
@LethalPerformance
@aleccolin - Did you end up getting one of these sprung hub clutch kits?
I’m building a Factory Five car that will be Coyote + T56 Magnum and I’m looking for a clutch for it. Car will be about 1,000 pounds lighter than the typical S550 Mustang, and make 500-ish rwhp. Daily driver with regular monthly autocross and HPDE.
Stock 15-17 flywheel is 28 lbs, and I want something around 15-20 lbs, along with at least 1 of the 2 clutch discs having sprung hubs. Combine that with the RST/RXT floater plate being strap driven, and it should have excellent street manners while offering great holding power for my NA engine up to the possible 750hp supercharger level I’ve been considering.
aleccolin
VA
www.CarClubVT.com
Colin
2016 GT PP
@LethalPerformance
No, I went with Tilton. Sent you a PM so as not to shit in this thread.
TRDFurgesson
Mid Ohio
www.youtube.com
Bobby
22 Mach1 N0426, 22 Bronco Wildtrak 2dr, 92 Yota 4x
Lets bring this into this decade... What options do I have for the 21-23 Mach 1?
Ls_Eater
Apollo Beach
Parker
2018 Magnetic Metallic GT
Mcleod RXT & Mantic are the two main ones I'd be looking towards.
Although I'm sure we could likely pester Lethal into producing their LPX or LPXHD for the GT350 as well!
