This. Its happened to me as well :lol:and for the record, the traction control always worked fine our 2015, very evident by killing my burnout on several occassions when i forgot to disable.....
Oh no, TC is always active as it's a function of ABS modulator - PCM sends the current amount of calculated torque and ABS modulator decides to activate the ESP or not.
Those are TORQUE controlled PCM's - the most difficult PCM's to tune. I've seen some Lund nGauge logs and YOU CAN'T tune the torque model with the data provided in those logs. Ask any STAND ALONE tuner you want...
Lund FORCES you to install their OWN specific Operating System - that is why flashing with nGauge takes 10 minutes while flashing the calibration with HP Tuners takes seconds. Nobody really knows what exactly Lund did in their OS as HPT will not read Lund OS. They can but agreed not to.
If LUND screws something up in your tune(they blew few engines in the past anyways - yes we know..) you can't even tell that something was wrong as they disabled like 70% of OBD data. Whipple tunes are even worse - OBD data is COMPLETELY turned off.
I would never load a tune that blocks or manipulates the OBD data - this is my car, not Lund's. If I buy a Hellion turbo kit Hellion will not weld my hood shut only because they want to protect their work...LUND does it only to avoid any liability in a case of blown engine or accident.
My car traps 122mph (so it has a decent bit of power) and I can cut up on the street so long as I have TC on. I notice a huge difference if it's off.They do as they switch the torque model off as they install a special operating system in your PCM. Electronic stability will not work properly without torque model - it will prevent your wheels form spinning but it will not save your ass if you whole car starts to spin - ever wondered why so many crashed mustangs and most of them with a tune? Go figure...
does this really work? I haven't had a chance to pull out the navi yet.I have no dog in the fight because I don't even have a tune for my car yet (Still waiting on my build to be done). But I find it funny that this Steve guy is talking all this trash when most tuning companies don't play tricks in the tune (Which is all you can do with the S550, because there is not a switch like the 11-14's that work because of the BCM control over a lot more) to turn off TC on the S550. If you want to disable traction control and advance track just unplug the connector under the airbox on the driver side. It's a dyno switch that's there from the factory that disables all of that. No tune changes needed.
Some cars don't have that connector. Well they do but it doesn't connect to anything it just has a dummy plug in it and goes no where.if you want to disable traction control and advance track just unplug the connector under the airbox on the driver side. It's a dyno switch that's there from the factory that disables all of that. No tune changes needed.
They should be identical aside from idle, in theory. However, they say not to run the ghost cam regularly as it is only a novelty tune. I'd run the normal myself.does this really work? I haven't had a chance to pull out the navi yet.
also one more question speaking of Lund tunes, what do you guys think would run better at the track... the normal Lund flex tune or the ghost cam flex tune?
https://www.mustang6g.com/forums/showthread.php?t=65198&highlight=dyno+fuseJust Incase was there a fuse or way to deactivate the tc or no?
Why? The guy is clearly on crack and wrong.I think the WHIPPLE rep needs to chime in here and set this straight. [MENTION=13288]Whipple SC[/MENTION]
