Have you noticed any difference in performance the LSD of the 3.31 and the torsen in the 3.73?I swapped the pumpkin.
I switched out the gears so I could keep the Torsen.You guys who are FI and have switched from 3.73's to 3.31's. Did you just switch out the gears or entire pumpkins? I just picked up a new 3.31 take-off pumpkin to replace the 3.73's, and now second guessing myself. I'll be doing occasional drag strip runs, so should I have just put 3.31 gears in my existing differential, so that I still have use of the torsen diff, or will the LSD be fine in the 3.31 pumpkin?
I swapped the whole thing. Found a take off unit for 299$You guys who are FI and have switched from 3.73's to 3.31's. Did you just switch out the gears or entire pumpkins? I just picked up a new 3.31 take-off pumpkin to replace the 3.73's, and now second guessing myself. I'll be doing occasional drag strip runs, so should I have just put 3.31 gears in my existing differential, so that I still have use of the torsen diff, or will the LSD be fine in the 3.31 pumpkin?
