ShiftPoint
- Jan 22, 2018
- Canal Winchester, Ohio
- Website
- www.youtube.com
- Shawn
- 2017 Ford Shelby GT350
I bought mine about a month ago and love the car! Had a boosted 2000 GT with full coil overs (MM), torque arm and Panhard setup etc. I have about 5 years of HPDE events, usually, run with the advanced group and instruct as needed. On my previous car, I ran NT01's and loved them. Mainly because they lasted a long time and never ran Hoosiers or a better tire for comparison.
I wanted to set the stage a bit. I did a bunch of searching before posting this too. In most of the posts the "recommended" (recommended by other members of the forum) camber (front), was over -2 degrees up front. If I had to generalize I would say -2.5 degrees up front. However, it seemed to be all over the place. I know it can depend on various things such as tires and other modifications. Right now as a baseline I wanted to start with what Ford Performance recommends and modify as needed. I can check tire temps at the first event but wanted to see what you guys thought.
Below are the photos from the "Track Tips" brochure that is included in the owner's supplement. Its recommending -1.5 degrees up front (non R) whereas stock is (-1.05 degrees). So here are my questions:
1. Will the stock adjustment front and rear allow the dealer or shop to set the camber to the specs they (Ford Performance) recommends? Meaning no need for CC plates.
2. If yes, have any of you guys run an HPDE event with the stock wheels and tires? Did it wear the outer edges? Did tire wear seem reasonable on track?
3. Did you end up finding -1.5 degrees of camber up front wasn't enough? You ended up installing the CC plates and now run -X.X amount of camber and are finding reasonable / pretty even tire wear with R compound or even the stock tires?
Let me know your thoughts! Looking forward to the feedback!
And one of the car
And one of the car
