F1R ProCharger questions
foff667
Clermont, FL
2014 Mustang GT Procharged D1X
You’re going to need a return fuel system, injectors, use e85, run the largest pulley (lowest boost) possible and you’ll still make 1000whp+ depending on shift point. Also you could lower the shift point to make less boost since it’s rpm dependent. FWIW I’m on a 5” blower pulley, shift @ 7800rpm and see 17psi...this is basically as “turned down” as it gets and I still went almost 150mph in 1320’ lol.
Pics of your setup or it didn't happen:eyebulge::eyebulge::eyebulge:
2qwk4ya
2017 gt, 401a, auto
And you have the baby F1A blower. with the 5" pulley spinning 67,392 rpm @ 7800 which is 90% of your 74k max. recommended blower speed.
The F1R has a max speed of 68,000. and with a 5" pulley it would be 67,392@ 7800rpm 99% of max. and its rated for another 150hp more than the F1A.
I don't think you can run any bigger than a 5" pulley on the stock hood with liner. and I bet that blower would see 25+ lbs. @7500
It also has the larger 9 3/4" volute over the 9" IDK if you could even install a airfilter for the street.
There's no way that F1R should be on a stock bottom end street car. you will never be able to control boost unless you wastegate it. And the stg II intercooler is already struggling with the smaller F1A without a wastegate.
Tommy V
Brookly park Md
Tommy
Yup like I said would not even make sense to put that on a stock motor lol!!!.
2qwk4ya
2017 gt, 401a, auto
Lcain_s550
Nashville
Logan
2015 Mustang GT PP
Thanks for the great feedback. Most likely just going stage 2 ho kit with p1x unit. Thanks again
ahl395
Allan
I agree with others that it would be more trouble than it's worth. Just go with a P1X or D1X.
However to share my 2 cents on wastegating. I wastegated my P1X, even after doing a converter, and it made an incredible difference. On the track it might not do much, but it makes the car feel so much better on the street.
