Rum_Punch_Ruby's Garage
Specs, Mods, Photos
YEAR
2017
MAKE
Ford
MODEL/TRIM
Mustang GT Premium
COLOR
Ruby Red Metallic
ENGINE
5.0 V8
TRANSMISSION
MT-82
PACKAGES
Performance Pack
FACTORY OPTIONS
Recaros
MODS - POWERTRAIN / DRIVETRAIN
- Edelbrock 2300 Supercharger "Stage 2"
- NGK 6510 spark plugs
- Edelbrock CAI
- DW 95lb fuel injectors
- VMP plug-n-play BAP
- Steeda clutch assist spring
- MGW x-spec shifter with standard handle
- BG Syncro Shift II fluid
Under hood mods
- JLT 3.0 oil separator
- plasti-dip coolant overflow tank
- JLT master cylinder cover
- Redline Tuning hood struts
- MMD radiator extension covers
- Anchor Room under hood pony decal
Exhaust
- Krona 3" cat-back w/ gloss black powdercoated tips
MODS - SOFTWARE / TUNE / PROGRAMMER
Lund Ngauge tuned
MODS - WHEELS / TIRES / BRAKES
- Project 6GR Seven gloss black
19x10 front 19x11 rear
- Nitto NT555 G2; 285/35/19 front 305/35/19 rear
- Steeda two piece lightweight rotors front and rear
- Ruby Red painted brake calipers
MODS - SUSPENSION / CHASSIS
- Steeda Active shocks and struts
- Steeda Sport Progressive springs
- Steeda billet rear shock mounts
- Steeda bump stops
- Steeda camber plates
- Steeda vertical links
- Steeda subframe support braces
- Steeda subframe bushing support system
- Steeda subframe alignment kit
- Steeda extreme G-trac brace
- Steeda Full-Length, Low-Profile Jacking Rails
MODS - EXTERIOR
- 15% window tint
- black OEM 5.0 badges
- fender "supercharged" badges
- black vinyl wrapped roof
- GT350 track pack spoiler
- Diode Dynamics LED reverse light
- Diode Dynamics LED rear side marker lights
- Craig's Custom removable front license plate bracket
- tinted tail lights
- Rokblokz splash shields
- customcargrills front grill inserts
- MF Auto Designs coyote grill badge
- Ford Performance 2018+ rear decklid w/ MF Auto Designs coyote badge
MODS - INTERIOR
- Diode Dynamics LEDs (red map/glove box/trunk lights and cool white vanity lights)
- GT350 start button
- GT350 dash
- GT350 door panels
- GT350 shift, cupholder, and steering wheel trim
- suede shift and e-brake boots
- custom suede Recaro seat inserts
- Raceseng slammer shift knob
- CM Components rear seat delete with LED pony
- SpaceCitySpy trunk close strap
MODS - IN-CAR ELECTRONICS
- 18+ digital cluster
HISTORY / COMMENTS
Purchased new 08/22/17 with 44 miles
Oil change 9/28/17 - 1212.5 miles; Mobile 1 full synth 5w20 and K&N filter
Oil change 04/03/18 - 5001.3 miles; FoMoCo synth blend 5w20 and FoMoCo filter
Oil change 04/03/19 - 9103.3 miles; FoMoCo synth blend 5w20 and FoMoCo filter - added Fumoto oil drain plug
Edelbrock Supercharger install 7/1-5/19 - 10,003.5 miles
Oil change 11/01/19 - 11,080.1 miles; FoMoCo snyth blend 5w20 and FoMoCo filter
additional parts:
Coverking Satin Stretch car cover
Covercraft sun shade
TrackSpec hood vents (not installed)
Steeda one piece 3.5" aluminum drive shaft (not installed)
rear seats/seatbelts
Stock manifold and misc bits
Comments
Item information
Added by
rum_punch_ruby
Views
1,269
Comments
Last update
More in Mustang GT
Share this item
