The Pearl (in hibernation!)
Specs, Mods, Photos
YEAR
2020
MAKE
Mustang
MODEL/TRIM
GT Premium Fastback
COLOR
Oxford White
ENGINE
5.0L Gen 3 Coyote
TRANSMISSION
10-Speed Automatic
PACKAGES
400A
FACTORY OPTIONS
Black Accent Package, Active Valve Performance Exhaust, Bang & Olufsen Sound System (12 Speakers & Subwoofer)
MODS - POWERTRAIN / DRIVETRAIN
Ford Performance Cold Air Intake, Throttle Body Adapter & 87mm Throttle Body
Airaid Blue Air Filter High Performance
Ford Performance Passenger Side Oil Separator
MRT Resonator Delete H-Pipe
Ford Performance Hood Strut Kit
Boomba Sound Tube Delete
Boomba GT Aluminum Dipstick Handle - Black
CPC Master Cylinder Cover - Black Textured
CPC Radiator Overflow Tank Cover -Black Textured
MODS - SOFTWARE / TUNE / PROGRAMMER
Ford Performance Calibration
SCT Burst Throttle Booster
MODS - WHEELS / TIRES / BRAKES
18ā€™ā€™ x 11ā€™ā€™ ET 52 APEX VS-5RS Black Satin Forged rear wheels
305/40R18 NITTO NT555RII rear tires
25mm Hub Centric Billet Aluminum front Wheel Spacers -Black
Gorilla Lug Nuts Factory Bulge (w/Lock Nuts) - Black Chrome
MODS - SUSPENSION / CHASSIS
Steeda Ultra-Lite Low-Profile Full Length Jacking Rails - Black
Steeda Urethane Differential Mount Bushing Inserts
Steeda IRS Subframe Alignment Kit
Steeda IRS Subframe Bushing Support System
Steeda IRS Subframe Support Braces
Boomba Rear Vertical Links - Black
Steeda 1ā€ Adjustable Rear Sway Bar
Steeda Billet Sway Bar Mounts
Steeda Adjustable Rear Sway Bar End Links
Steeda Pro-Action Rear Shocks
Steeda Pre-cut Bump Stop/Jounce Bumpers
Steeda Billet Rear Shock Mounts
Steeda Sport Progressive Lowering Springs
Steeda Rear Lower Control Arm Spherical Bearings
Steeda Rear Camber Arm Adjustable Brackets
Steeda Adjustable Camber Arms
Steeda Adjustable Rear Toe Link's
Ford Performance Knuckle to Toe Link Spherical Bearings
Steeda Mustang Strut Tower Brace
Steeda Extreme G-Trac Brace
Steeda Front Lower Control Arms w/bearings
Steeda Adjustable Front Swaybar Endlinks
Steeda 1.5ā€ Adjustable ā€œMassiveā€ Front Swaybar
Steeda Billet Front Sway Bar Mounts
Steeda Bump-steer Kit
Steeda Adjustable Front Camber Plates
Steeda Front Linear Lowering Springs
Steeda Pro-Action Front Struts
MODS - EXTERIOR
Over-the-Top Ebony 12 & 2 Racing Stripe
Hood Louvers by Air DesignĀ® ā€” Gloss Black
Quarter Window Louvers by Air DesignĀ® ā€” Matte Black
Anchor Room Complete Front And Rear Light Tint Kit
Axial LED Side Marker Lights; Rear; Smoked
Diode Dynamics LED Reverse Light Bulb
S550 Euros Bright White LED License Plate Lights
Vland Euro Clear Taillights
Black Knurled Aluminum Valve Stem Caps w/Mustang Pony Logo
American Muscle Rocker Stripes - Matte Black
Roush Performance Rocker Winglets
Roush Performance Rear Valance Diffuser Kit
MODS - INTERIOR
Shrader Rear Seat Delete
Weather Tech DigitalFit Floorliners, Front Seat, Black.
Steeda Billet Aluminum Hood Latch Release
Steeda 2" Wide Seatbelt Harness Pads, White Lettering
MODS - IN-CAR ELECTRONICS
Ford Performance Pro Cal 4
HISTORY / COMMENTS
Purchased new in September 2020. This is my 4th Mustang.
Comments
The best 0-60 time Iā€™ve gotten so far with my setup is 5.0 seconds. Iā€™ve tried track & drag strip modes. Outside temp. in the 15C range (~50F). Any tips on getting into the mid 4 second range where it should be?
Item information
Added by
Haulinā€™ator
Views
3,534
Comments
Last update
More in Mustang GT
Share this item
