- Dec 8, 2014
- San Luis Obispo, CA
- 2002, 2006, 2015 Mustangs
Ohlins Road & Track Adjustable Coil Over Kit Front & Rear
2015-2018 Ford Mustang
Ohlins Adjustable Front & Rear Coil-Over Kit
Part # FOS MR00
Use Coupon Code mustang 6g at checkout to save 5%
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises is over. We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products – worldwide. Öhlins Road & Track team has extensively tested a wide variation of springs to find the right balance between road and track use. By testing in different conditions on road as well on track, the listed spring rate is what we strongly recommend you to use.
GENERAL FEATURES:
DFV (Dual Flow Valve)
Rebuildable
Corrosion salt spray tested (ISO 9227)
2 year limited warranty
Front Features:
McPherson strut
Single bleed adjuster
Spring preload adjuster (approx. 25 mm lower than standard)
Coil springs
Dustcovers
Rear Features:
Conventional shock absorber
Length adjuster
Coil springs
Dustcovers
Springs:
FRONT 90 N/mm
REAR 140 N/mm
Part # FOS MR00
GENERAL FEATURES:
Rebuildable
Front Features:
McPherson strut
Coil springs
Dustcovers
Rear Features:
Length adjuster
Coil springs
Dustcovers
Springs:
FRONT 90 N/mm
REAR 140 N/mm
